Linux Mint with RTAI
17 Nov 2016 13:13 #82894 by andypugh
Replied by andypugh on topic Linux Mint with RTAI
"Something" is trying to compile "something" with no connection to LinuxCNC and failing.
I suspect that the RTAI kernel you are trying to use ( 3.4-9 ) isn't the right one for the Mint version.
17 Nov 2016 14:01 #82896 by Patrick Obrien
Replied by Patrick Obrien on topic Linux Mint with RTAI
The version specified in this thread is 3.4-9, so rather than reinvent the wheel I am following the cookbook notes in this thread and hoping someone else had followed this thread an gotten past this error.
My PC is a HP C2 Duo so nothing tricky there.
Not sure why this is failing.
17 Nov 2016 14:15 #82897 by andypugh
You probably don't even need ndiswrapper, and looking at the code:
sourceforge.net/p/ndiswrapper/code/HEAD/...wrapper/driver/crt.c
it isn't clear what particular devices use crt.c
Do you have a wireless network dongle plugged in?
17 Nov 2016 15:03 #82901 by Patrick Obrien
I do, no cat 5 to the garage.
I will bring the PC into the house and start over.
Great catch Andy - thanks
I will report on the progress.
17 Nov 2016 18:59 #82915 by Patrick Obrien
I reloaded from scratch with the dongle off and hardwired to the router.
DKMS make.log for ndiswrapper-1.59 for kernel 3.4-9-rtai-686-pae (i686)
Thu Nov 17 12:53:58 CST 2016
make: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
LD /var/lib/dkms/ndiswrapper/1.59/build/built-in.o
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/crt_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/hal_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/ndis_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/ntoskernel_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/ntoskernel_io_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/rtl_exports.h
MKEXPORT /var/lib/dkms/ndiswrapper/1.59/build/usb_exports.h
CC [M] /var/lib/dkms/ndiswrapper/1.59/build/crt.o
/var/lib/dkms/ndiswrapper/1.59/build/crt.c: In function ‘_win_srand’:
/var/lib/dkms/ndiswrapper/1.59/build/crt.c:470:2: error: implicit declaration of
function ‘prandom_seed’ [-Werror=implicit-function-declaration]
cc1: some warnings being treated as errors
make[3]: *** [/var/lib/dkms/ndiswrapper/1.59/build/crt.o] Error 1
make[2]: *** [_module_/var/lib/dkms/ndiswrapper/1.59/build] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
make: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
17 Nov 2016 19:13 #82916 by andypugh
An idea from the IRC, you could try uninstalling ndiswrapper through the package manager, and see if things work better then.
17 Nov 2016 19:17 #82917 by tommylight
Replied by tommylight on topic Linux Mint with RTAI
Why use ndiswraper ? If i remember correctly there are other proprietary drivers for broadcom cards. Do you get any other option, like btxxx drivers ???
I do not have any of those, but i know that you get a choice of them in Linux Mint and Ubuntu when using the driver manager that comes with those distributions.
I know from experience that ndiswraper will mess up the system in 80% of installs, and some times irreversible.
Hold on leme read ............nope no mention of the wifi chipset, so i gues it is broadcom.
17 Nov 2016 19:31 - 17 Nov 2016 19:35 #82919 by Patrick Obrien
I will.
Last edit: 17 Nov 2016 19:35 by Patrick Obrien.
17 Nov 2016 19:34 #82921 by Patrick Obrien
I am following the cookbook notes in this thread exactly with no modifications. I installed from the downloaded Mint ISO with no additional software. The ndiswapper was unexpected. This is a standard HP Tower with no built in wireless.
17 Nov 2016 21:40 #82931 by Patrick Obrien
I will.
Andy - Thanks! That did it, I got past the ndis error.
Thankfully this is documented for the next guy.
Time to create page: 0.186 seconds
