- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
17 Apr 2017 16:14 #91517
by probamo
Replied by probamo on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- cncnoob1979
- Topic Author
- Thank you received: 75
17 Apr 2017 16:33 #91519
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Glad you got it going!
You will need to start a new thread to configure linuxcnc please. I would like to keep this thread just for the install portion only.
Is this on a VM? Because
You are not using a real-time kernel at the moment.... the "non-realtime" indicates this.
Did you make your kernel fully Preemptible as instructed in the how-to?
The reason your ini/hal is failing is because it is looking for a paraport #0 and can not find it.
Debug file information:
Note: Using POSIX non-realtime
Linux parallel port #0 not found
17 Apr 2017 16:35 - 17 Apr 2017 16:36 #91520
Replied by andypugh on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Although computer is not bad, latency is huge
You might need to reconfigure grub to choose the right kernel.
What does uname -a say?
Last edit: 17 Apr 2017 16:36 by andypugh.
- cncnoob1979
- Topic Author
17 Apr 2017 16:36 #91521
by cncnoob1979
4.9.4-rt2 is the kernel you are using there right?
Seems to me you when you built the kernel you did not select the fully preemtable option. That is a common latency when you fail to select it. No worries; just build anther one and install it on the same machine. You can easily switch between the two.
17 Apr 2017 16:37 #91522
by probamo
kernel is 4.9.4-rt2 and on real PC, not in VM
17 Apr 2017 16:38 #91523
by probamo
I'll give a try again.
- cncnoob1979
- Topic Author
17 Apr 2017 16:39 - 17 Apr 2017 16:41 #91524
by cncnoob1979
can you post your uname-a printout as asked by andy please?
EDIT: Typo!
EDIT: Typo!
Last edit: 17 Apr 2017 16:41 by cncnoob1979.
17 Apr 2017 16:42 #91525
by probamo
hereafter enclosed
- cncnoob1979
- Topic Author
17 Apr 2017 16:44 #91526
by cncnoob1979
sorry: I had to edit my post:
I was needing the uname -a
You can just paste it in the forum...
17 Apr 2017 16:49 #91527
by probamo
here is uname -a attached
- General
Time to create page: 0.271 seconds
