PCI parallel port disabled with Wheezy / Linuxcnc 2.7
13 Aug 2022 17:13 #249663 by adouglas89
you can also just put that memory address into the place where the stepconf asks for the parport base address, apparently. That way you can use stepconf properly to do your setup while having the parport working. So instead of 0, enter 0xe010, for instance.
Time to create page: 0.142 seconds
