- Thank you received: 127
ozzyrob wrote: This is just a brief overview.
Ok I have compiled and installed a kernel, I went with 4.11.12 as it was the closest to the Mint kernel with a RT patch.
Runs OK.
Compiled and installed Linuxcnc-uspace_2.7.14, axis sim runs ok
Had to manually build and install mesflash.....that's good now
Now The fun part.....
To get hm2_eth to load without any errors I had to do the following......this is just a rough explanation without any instructions.
Get Mint to load the kernel modules ip_tables & iptable_filter on boot
Had to change the permissions of sysctl & iptables so they run as root.......I'm not exactly happy with this solution, but should be ok if you are the only with access to the machine and net access can be limited (this is paranoia speaking)
But after those changes I was able to test connect to my 7i92 board, I haven't got it connected up yet, just going thru a testing phase to get used to it, rather than going the "whole hog" having to fix 1000 issues at once.
