Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #112751 by Hakan
Bengt, doesn't this mean that it selected something else than the deb package you asked for?
Perhaps you should have used "apt deb"?
bengt@CNC3000 ~/Hämtningar/mint-cnc $ sudo apt install ./linuxcnc-uspace_2.7.14_amd64.deb Läser paketlistor… Färdig Bygger beroendeträd Läser tillståndsinformation… Färdig Observera, väljer "linuxcnc-uspace" istället för "./linuxcnc-uspace_2.7.14_amd64.deb"
8 years 4 months ago #112752 by tecno
I just followed instructions from Rob
8 years 4 months ago #112754 by tecno
OK Guys = it is over and out with this NUC !
Been running LCNC for a while and closed down to start latency-histogram.
It starts but as soon as I start adding GLX Gears it freezes totally !
Will edit grub.cfg and have following and run tests again
isolcpus=2,3 intel_idle.max_cstate=1 i915.enable_rc6=0 i915.enable_dc=0
But if it fails it is all over for this NUC.
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112757 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
I think the compiling error is related to ndiswrapper, not an issue unles you are using that. The firmware issue I searched and that seems to be something that is not an issue.
Is there a bios setting to change the amount of graphics ram ?
The machine I built the packages on uses the i915 graphics as well and I didn't have any issues.
8 years 4 months ago #112758 by tecno
Will have a look around in BIOS later. Just trying to beat the hell out this now and see if I can get it to freeze again.
So far so good with the new grub settings.
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago - 8 years 4 months ago #112760 by ozzyrob
See if there is an option to turn DVMT
Dynamic Video Memory Technology.
I found a page with some info on the i915 gpu
wiki.archlinux.org/index.php/intel_graphics
This section looks interesting
wiki.archlinux.org/index.php/intel_graphics#Xorg_configuration
Last edit: 8 years 4 months ago by ozzyrob.
Time to create page: 0.403 seconds
