Upgraded to 2.7.13 -- W T F --
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112777 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
Glad you are getting results......those figures do look good.
8 years 4 months ago #112779 by tecno
Feeling more confident now after intensive testing.
No freezing so far, tomorrow I will copy over my settings and hook it up on my lathe.
8 years 4 months ago - 8 years 4 months ago #112786 by tecno
Just of curiosity I deleted isolcpus=2,3 and BOOOM there it was again FREEZE.
Last edit: 8 years 4 months ago by tecno.
8 years 4 months ago #112791 by tecno
Quick update.
The NUC is now operational on my lathe, been running som tests and all looks OK.
Have some small issues that I will adress in next message.
8 years 4 months ago #112794 by tecno
Here are my errors I get, note this is only now when PC is connected in lathe to my 7i76e+7i85s
modprobe: ERROR: could not insert 'ip_tables': Operation not permitted iptables v1.6.0: can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. hm2_eth: ERROR: Failed to create iptables chain hm2-eth-rules-outputhm2_eth: WARNING: Unable to restrict other access to the hm2-eth device. This means that other software using the same network interface can violate realtime guarantees. See hm2_eth(9) for more information.
modprobe: ERROR: could not insert 'ip_tables': Operation not permitted iptables v1.6.0: can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. hm2_eth: ERROR: Failed to execute '/sbin/iptables -A hm2-eth-rules-output -o enp3s0 -p icmp -j DROP'
Unexpected realtime delay on task 0 This Message will only display once per session. Run the Latency Test and resolve before continuing. Unexpected realtime delay on task 0 This Message will only display once per session. Run the Latency Test and resolve before continuing. Emit interp-run hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently. hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently. /usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x5800003 unexpectedly destroyed gtk.main() **** GLADE VCP ERROR: X Protocol Error: 3
Hopefully somebody can see what might be wrong here.
Enclosed my latest INI HAL and above error.txt in ful
File Name: errormessage.txt
File Size:5.71 KB
File Name: CNC3000_20...6-23.ini
File Size:3.55 KB
File Name: CNC3000_20...6-23.hal
File Size:13.2 KB
8 years 4 months ago #112796 by tecno
Got a freeze up again, left power on and just the first screen in Mint for over an hour without any activity and PC was frozen.
Reboot and open LCNC and I immediately get
Did leave it now with latency-histogram running so I will go down to the workshop after a while and see if it is working or if it has frozen.
Time to create page: 0.078 seconds
