Upgraded to 2.7.13 -- W T F --
8 years 3 months ago #113496 by tecno
hm2/hm2_7i76e.0: Watchdog has bit! (set the .has-bit pin to False to resume)
hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently.
hm2/hm2_7i76e.0: Smart serial card hm2_7i76e.0.7i76.0.0 local error = (13) Communication error
hm2/hm2_7i76e.0: Smart serial card hm2_7i76e.0.7i76.0.0 local error = (3) Timeout
hm2/hm2_7i76e.0: Smart Serial Comms Error: There have been more than 1 errors in 10 thread executions at least 200 times. See other error messages for details.
hm2/hm2_7i76e.0: ***Smart Serial Port 0 will be stopped***
8 years 3 months ago - 8 years 3 months ago #113497 by PCW
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
That's a latency issue
I would first make sure the all power management/speed switching is disabled in the BIOS and remove the isolcpus statement in the grub config
Isolcpus typically improves dispatch latency (what the latency test and histogram display) but very often makes Ethernet latency worse
Another possibility is complete loss of communications (the watchdog bite suggest this since that means communications
have dropped out for > 50 ms) This might be a power issue on the 7I76E (if power drops out and it resets, this will happen)
Last edit: 8 years 3 months ago by PCW.
8 years 3 months ago #113500 by tecno
Hi Peter,
If I take isolcpus out the latency values goes really bad, have a look forum.linuxcnc.org/9-installing-linuxcnc...t-f?start=150#112879
As I recall all power management is disabled
8 years 3 months ago #113504 by PCW
The all cores plot indicates something else is wrong, do you have WIFI enabled?
That will cause that type of latency on a BXBT1900 for example BXBT1900 with no WIFI:
BXBT1900 with WIFI:
Ethernet latency depends to some extent on gross CPU speed, you throw 1/2 of this away with isolcpus 2,3
  • ozzyrob
  • New Member
  • New Member
8 years 3 months ago #113507 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
Considering all the changes made and the error appears to be the same, I'd be looking at anything that has been the same through all this.
8 years 3 months ago #113508 by tecno
It is there physically (built in this NUC) but as I have no WiFi at the moment so I think it is disabled.
Even if I have WiFi (next week I will get new gear) it will be only activated when need to update etc.
Time to create page: 0.322 seconds
