Upgraded to 2.7.13 -- W T F --
8 years 3 months ago #113807 by tecno
PCW wrote: did you run the editor as root?
And still nothing of the edit in the file!
What is this?
8 years 3 months ago #113808 by PCW
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
You are editing the wrong file
you should edit /etc/default/grub
grub.cfg is overwritten every time you run update-grub
8 years 3 months ago #113810 by tecno
Oh my oh my.... this is what I have been doing earlier and it has been working, but it maybe so that I have not 'update-grub' and therefore it has been working.
So how do I do this the correct way?
# If you change this file, run 'update-grub' afterwards to update # /boot/grub/grub.cfg. # For full documentation of the options in this file, see: # info -f grub -n 'Simple configuration' GRUB_DEFAULT=0 GRUB_HIDDEN_TIMEOUT=0 GRUB_HIDDEN_TIMEOUT_QUIET=true GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian` GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" # Uncomment to enable BadRAM filtering, modify to suit your needs # This works with Linux (no patch required) and with any kernel that obtains # the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...) #GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef" # Uncomment to disable graphical terminal (grub-pc only) #GRUB_TERMINAL=console # The resolution used on graphical terminal # note that you can use only modes which your graphic card supports via VBE # you can see them in real GRUB with the command `vbeinfo' #GRUB_GFXMODE=640x480 # Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux #GRUB_DISABLE_LINUX_UUID=true # Uncomment to disable generation of recovery mode menu entries #GRUB_DISABLE_RECOVERY="true" # Uncomment to get a beep at grub start #GRUB_INIT_TUNE="480 440 1"
So where do I insert this line?
isolcpus=2,3 intel_idle.max_cstate=1 i915.enable_rc6=0 i915.enable_dc=0
  • AnnoyingMutt
  • New Member
  • New Member
8 years 3 months ago #113812 by AnnoyingMutt
Replied by AnnoyingMutt on topic Upgraded to 2.7.13 -- W T F --
Change this line:
To:
GRUB_CMDLINE_LINUX="isolcpus=2,3 intel_idle.max_cstate=1 i915.enable_rc6=0 i915.enable_dc=0"
8 years 3 months ago #113813 by tecno
Did it the "wrong" way and edited grub.cfg and did not do update-grub. Everything is now running OK as it looks and I can't replicate earlier freeze conditions. The result should be the same, right?
8 years 3 months ago #113816 by PCW
You can do this but it will eventually bite you as some other operations run update-grub
Time to create page: 0.299 seconds
