- Thank you received: 5334
tecno wrote:
PCW wrote: WIFI is _not_ disabled unless you specifically turn it off (it will spend its time searching for WIFI signals if not disabled)
I would
1. Remove the isolcpus statement from grub and run update-grub
2. Reboot
3. Disable WIFI
4. Try LinuxCNC again
The 7I76E takes very little 24V power so I was more thinking of a bad connection (24V with 5V of ripple would run the 7I76E fine)
The latency tests are sporadically good in that I get no freezing! Starting test is OK but adding GLXGEARS freeze's the PC.
No errors in LCNC what I have noticed so far, but something is very wrong as PC freeze“s in Latency test.
Bios is clear no power saving mumbo jambo, WiFi is disabled but still physically connected.
I'm inclined to go back with isolcpu's as that setting gave me no FREEZE.
So any more test I can do to find this bugging problem, I am all ears
