Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #112818 by tecno
I get some error messages still and would like to solve these if possible.
Unexpected realtime delay on task 0 This Message will only display once per session. Run the Latency Test and resolve before continuing. Unexpected realtime delay on task 0 This Message will only display once per session. Run the Latency Test and resolve before continuing. hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently. hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently.
Is this message saying that
Running HAL shutdown script
task: 45326 cycles, min=0.000019, max=0.127551, avg=0.010016, 1 latency excursions (> 10x expected cycle time of 0.010000s)
P = 1000.0 and SERVO_PERIOD = 1000000 are set too short so P=1500 and SERVO_PERIOD = 1500000 could solve this issue?
I can run ngc files and get no error during running lathe_pawn.ngc, I can override feed to 200% = no problems.
File Name: CNC3000_20...6-24.ini
File Size:3.75 KB
File Name: CNC3000_20...6-24.hal
File Size:13.2 KB
8 years 4 months ago #112822 by tecno
P=1500 and SERVO_PERIOD = 1500000 seems to be working = no more pop up error message on screen.
8 years 4 months ago - 8 years 4 months ago #112876 by tecno
Received my Gigabyt GB-BXBT-1900 today and installed Mint 18.3
Following 2 lines Error file not found or something like that
sudo apt-get install hostmot2-firmware-all mesaflash
sudo apt install glade3_3.8.6-1_amd64.deb >>>>>>>>>>>>>>>>> solved double click on package!
Running LCNC in SIM faults like this
bengt@CombiMll ~ $ linuxcnc
LINUXCNC - 2.7.14
Machine configuration directory is '/home/bengt/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Note: Using POSIX realtime
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(lib): /usr/share/linuxcnc/hallib/lathe.hal
task: main loop took 0.012027 seconds
task: main loop took 0.012469 seconds
task: main loop took 0.021057 seconds
Did a short latency test and numbers are not good running all 4 cores = a bit disappointing.
Last edit: 8 years 4 months ago by tecno. Reason: edited text
8 years 4 months ago #112879 by tecno
Not good as you can see.
8 years 4 months ago #112883 by tecno
isolcpus=2,3
Now this looks OK to me
8 years 3 months ago #113494 by tecno
Obviously this story has not ended yet, still some errors!
I just rigged up work to be done and took a dinner brake and after about 2-2½ hours this on the monitor.
LNCN left power on but not F2 !!
Here the terminal output
File Name: latheerror...reak.txt
File Size:35.71 KB
I would appreciate if you guys can see something obvious that is way wrong in my setup here.
File Name: CNC3000_20...7-05.hal
File Size:13.2 KB
File Name: CNC3000_20...7-05.ini
File Size:3.78 KB
Time to create page: 0.136 seconds
