Upgraded to 2.7.13 -- W T F --
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Jun 2018 16:12 #112548 by tecno
Replied by tecno on topic Upgraded to 2.7.13 -- W T F --
Some good news and bad news.
1. booted 64 bit = lathe did run pawn.ngc without any problems.
!! Touch did work but bad calibration !!
2. did some browsing in catalogs back and forth = FREEZE !!!
3. booted 32 bit = lathe is running OK and Touch is working as it is calibrated.
dis same a lot of browsing and no problems, did leave running latency-histogram and will go back and see how it looks and if it is frozen or not.
I'll be back ;)
PCW wrote i915.enable_rc6=0 i915.enable_dc=0
Is this to be inserted on the same line as isolcpus=2,3 in grub.cfg? Maybe a cure for the freezing in 64bit??
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
18 Jun 2018 21:09 - 18 Jun 2018 21:09 #112559 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
Yes same line as isolcpus, that line is to do with the GPU, it shouldn't hurt to try it.
When you say freeze, can you elaborate as to what is actually happening ? Is it just one window, all windows is the system completely unresponsive ?
If you press CTR-ALT-F1 can you get a login text console and can you log in ?
CTRL-ALT-F7 should get you back to your desktop.
If you have irqbalance installed try removing it by
sudo apt-get remove irqbalance
I noticed that was installed with the realtime linux-image
Last edit: 18 Jun 2018 21:09 by ozzyrob.
  • tecno
  • Platinum Member
  • Platinum Member
18 Jun 2018 21:19 #112560 by tecno
Totally unresponsive. Will try your suggestions tomorrow.
  • tecno
  • Platinum Member
  • Platinum Member
19 Jun 2018 09:06 #112570 by tecno
Been down in the shop and tried to stress 64bit but now I cannot reproduce that freezing. It is now running latency test so I will see later on if I can get it freeze again.
  • tecno
  • Platinum Member
  • Platinum Member
19 Jun 2018 11:35 #112575 by tecno
Hmmm
I can not reproduce that freezing that I had yesterday, no files have been changed.
Lathe is powered and LCNC running but idle for a while the I will test again.
  • tecno
  • Platinum Member
  • Platinum Member
19 Jun 2018 16:33 #112590 by tecno
Well now it just froze again no responce from keyboard/mouse/touch and there is no other way than take out the power and reboot.
I have now added GPU lines to grub.cfg and I did remove irqbalance. Tested a short while but have to do some more testing tomorrow and see if it behaves as it should.
Only added
python-rsvg
Xinput calibrator
Xterm
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
20 Jun 2018 01:08 #112600 by ozzyrob
I'd try reseating the RAM modules and running memtest. Could be a bad memory location that the 64 bit OS is accessing that the 32 bit OS doesn't touch.
if you don't already have a grub menu selection for memtest run
sudo apt-get install memtest86
When you reboot there should be a grub menu item for memtest, select that, or if it is not in the main main it maybe hidden in the advance selection.
  • tecno
  • Platinum Member
  • Platinum Member
20 Jun 2018 04:45 #112607 by tecno
Will try that later today, now off to hospital for some X-ray of my hip and knee that are a bit problematic.
Later..
  • tecno
  • Platinum Member
  • Platinum Member
20 Jun 2018 09:45 #112612 by tecno
Installed memtest86, new entries in grub but not one of these works! Freezes up at once only restart will work.
I think I have to get another PC as this is just too much, looking at
www.computersalg.se/i/2234504/gigabyte-gb-bxbt-1900-bga-1170
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
20 Jun 2018 10:35 #112614 by ozzyrob
Looks like you got a bit of a lemon, was it brand new or second hand ?
I went with one of these, it's going in a cabinet with all the bits & pieces, probably not a solution for you.
www.newegg.com/global/au/Product/Product...Item=N82E16813157726
And one of these SSD's. The vendor sent me a 16GB module even tho I ordered an 8GB :)
www.ebay.com.au/itm/Industrial-Disk-on-M...p2057872.m2749.l2649
Might even consider one of those 12v mini supplies.
Time to create page: 0.170 seconds
