ozzyrob wrote: I'd try reseating the RAM modules and running memtest. Could be a bad memory location that the 64 bit OS is accessing that the 32 bit OS doesn't touch.
if you don't already have a grub menu selection for memtest runCode:sudo apt-get install memtest86
When you reboot there should be a grub menu item for memtest, select that, or if it is not in the main main it maybe hidden in the advance selection.
ozzyrob wrote: Looks like you got a bit of a lemon, was it brand new or second hand ?
I went with one of these, it's going in a cabinet with all the bits & pieces, probably not a solution for you.
www.newegg.com/global/au/Product/Product...Item=N82E16813157726
And one of these SSD's. The vendor sent me a 16GB module even tho I ordered an 8GB
Might even consider one of those 12v mini supplies.
