ozzyrob wrote: So it's boots ok and the graphics is good.
Running the debian rt kernel ok, apart from the latency-histogram ?
Linuxcnc was installed as per JT's instructions, should be version 2.7.13 ?
Before you run the latency-histogram run [(may have to use su or sudo)Code:dmesg -c
That will display the messages and then start with an empty buffer so anything new wont be lost in a 1000 other messages.
Have you triedCode:latency-histogram --nobase --verbose
When you go to close the latency-histogram window it does close ?
Is there anything in dmesg that looks odd ?
