Upgraded to 2.7.13 -- W T F --
8 years 4 months ago - 8 years 4 months ago #112101 by andypugh
ozzyrob wrote: Just thinking out load, would removing the 2.7.13 version via dpkg and installing the 2.7.12 version and booting with the 4.9.0-3 kernel be worth a try ?.
You can do that in the Synaptic Package Mangler.
Last edit: 8 years 4 months ago by andypugh.
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago - 8 years 4 months ago #112102 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
Thanks Andy I'm not totally up to speed with all things Debian.....been a longtime Slackware user.
Would it be worth tecno trying ?
Ok after a bit of delving I was able to work out how to use git to get the 2.7.12 checked out. Got rip to build and simulate and then built the required debs as well. I was just wondering if the uspace packages thru synaptic are tied to a certain kernel version..maybe not or they might "fall apart" with the updated packages.
Like I said the "Debian Way" is kinda new to this fossil.
Last edit: 8 years 4 months ago by ozzyrob.
8 years 4 months ago #112117 by tecno
Well guys, I do believe that this is the end of the road for this PC.
I do not think it will cut whats incoming in future as regards OS and LCNC.
Need to find a somewhat future proof PC on my more or less non-existing budget as I am on pension for new toys. So I need 2 new PC's one for the lathe and another for the milling machine.
Suggestions on what to look at is much appreciated.
Mini-ITX or smaller and single power, minimum 3 USB ports, ETH + WiFi if possible
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112122 by ozzyrob
Have you tried "rolling back" to 2.7.12?
I wouldn't throw in the towel with the hardware yet.
8 years 4 months ago #112123 by tecno
No LAN for some time until I get new exchanged LAN parts.
I can dig the PC out and bring it up to my house and try to do this but that will put me on 2.7.12 for the future and I 'm not so sure I want to stay there == IF IT WORKS.
As PCW wrote he suspects the OS upgrade that happened to be the culprit
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112124 by ozzyrob
Well at least it'll get you operational until you can get the funds together....
I know the feeling of limited funds, I've been out for way too long with back problems. Part of the problem is employers are reluctant to give you a go. :(
Time to create page: 0.338 seconds
