Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #112075 by tecno
bengt@CNC3000:~$ dmesg | grep eth
[ 2.365659] r8169 0000:02:00.0 eth0: RTL8102e at 0xf825f000, 00:30:18:a6:5b:cb, XID 14a00000 IRQ 26
[ 2.519553] r8169 0000:02:00.0 enp2s0: renamed from eth0
bengt@CNC3000:~$
Latency test is running now
8 years 4 months ago #112078 by tecno
Here the histogram
Just started another run with 4 GLX Gears
8 years 4 months ago #112080 by tecno
and this is from last july and have been working OK with 2.7.12
8 years 4 months ago #112082 by PCW
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
Seems similar but the OS version is different
My guess is this is either OS version related or that you have had some hardware failure coincident with the linuxCNC version change
8 years 4 months ago #112083 by tecno
OK, seems to a bit bad to try to 'go back'.
Is this a good choice for a new PC
Gigabyte Brix Mini-PC GB-BXBT-2807
I suppose 2G is not enough memory?
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112099 by ozzyrob
Replied by ozzyrob on topic Upgraded to 2.7.13 -- W T F --
Just thinking out load, would removing the 2.7.13 version via dpkg and installing the 2.7.12 version and booting with the 4.9.0-3 kernel be worth a try ?
Would it still be possible to checkout 2.7.12 via git ? And trying a run in place
I'm not totally up on git.
Time to create page: 0.412 seconds
