Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #111967 by tecno
PCW wrote: What does linuxcnc print when you start it?
(the first few lines)
File Name: topeter_20...6-08.txt
File Size:3.98 KB
8 years 4 months ago #111970 by tecno
andypugh wrote: Can you show us the output of:
cat /etc/apt/sources.list.d/linuxcnc.list
File Name: toandy_2018-06-08.txt
File Size:369 B
This output starting my backup CNC3000.ini and goes to error state
File Name: startbacku...3000.txt
File Size:47.59 KB
This happens after pressing F2 and grabbing the MPG to move Z
Now I get nowhere as after F2 it always goes to error.
8 years 4 months ago #111974 by andypugh
Are you sure you want to be running the config in the backup folder and not the main config?
I suspect that the relative path from the backup INI is not finding the lathemacro files.
But I am not sure what the 7i76 error means.
8 years 4 months ago - 8 years 4 months ago #111975 by tecno
No backup is a backup, just showing what is going on.
I have done no changes to my setup from 12 to 13 other that adding Touch screen on 12 then upgraded to 13.
Last edit: 8 years 4 months ago by tecno.
8 years 4 months ago #111976 by andypugh
I a, just going by
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u lathehandler.py -x 44040621 lathemacro.ui" exited with error: 1 Shutting down and cleaning up LinuxCNC... ... (gladevcp:1675): libglade-WARNING **: could not find glade file 'lathemacro.ui' **** GLADE VCP ERROR: With xml file: lathemacro.ui : could not create GladeXML object
Why are you running the backup config and not the main config?
8 years 4 months ago #111978 by tecno
Just to clarify, I get the same error in main as in backup = I was worried about something going on with the main to be corrupted.
So what you say is that my main folder has been FU as regards Lathemacro files?
Time to create page: 0.385 seconds
