Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #112021 by tommylight
tecno wrote: OK, I follow what you say.
So is it time to play with new numbers on P = 1000 on each axis and SERVO_PERIOD ?
1000000 or 1.000.000 without dots, that is one million,
On your reply you used one hundred thousand and three hundred thousand, that will not work properly.
8 years 4 months ago #112064 by tecno
That was a typo in my reply
8 years 4 months ago #112066 by tecno
Here a new test this morning
First part is with 1000000 setting and from line 100 the setting is 2000000
File Name: newtest.txt
File Size:9.08 KB
this picture with 2000000 and only keyboard jogging and it fails after a while.
8 years 4 months ago #112072 by PCW
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
This is all quite weird as the differences between 2.7.12 and 2.7.13 are not that significant and not related to Ethernet communications at all. I think something else must have changed when you updated, perhaps specific to your PC
Can you run a latency test on you PC to make sure something bad has not happened to real time...
something like
latency-histogram --nobase
and run it for 1/2 hour or so then use latency-histograms screenshot option to get the image and post it here
Also if you have an Intel MAC you need to set irq coalescing off (if you did not automate this setting you would lose it when you re-booted)
8 years 4 months ago #112073 by tecno
Hi Peter,
Will do that after my dinner.
Also if you have an Intel MAC you need to set irq coalescing off = sorry I do not understand what you say here, advice pls.
Only change on 2.7.12 was adding Touch and the update / upgrade
8 years 4 months ago #112074 by PCW
Do you have a intel MAC? (check with dmesg | grep eth)
The hm2_eth manual page describes setting the RX IRQ coalescing option
man hm2_eth
Time to create page: 0.097 seconds
