Upgraded to 2.7.13 -- W T F --
8 years 4 months ago #111990 by tecno
Now the hm2* error is no more but something is not OK as the jogging is not OK, a bit more stable with arrow keys than MPG that really is FU.
8 years 4 months ago #111995 by andypugh
It is possible that P = 1000 is not correct for a 2mS servo period.
Do you know why your servo period is 2mS?
8 years 4 months ago - 8 years 4 months ago #111996 by tecno
To be honest I do not remember how this was setup earlier. But it has been running well before this update/upgrade.
These old 5-phase stepperdrivers are not the fastest in the world and I think 'we' (you/Peter/me) came to this setting after examination of the settings I used in Mach3, If I recall step was 5µs and over 10µs on dir.
So what do you suggest me to try next?
Last edit: 8 years 4 months ago by tecno.
8 years 4 months ago #111997 by andypugh
This is all that supposedly changed between 2.7.12.and 2/7/13
www.linuxcnc.org/2018/05/09/LinuxCNC-2.7.13/
I suppose you could go back to 2.7.12 to see if the problem goes away?
(In the synaptic package manager select LinuxCNC then go to one of the menu tabs (I have forgotten which) and choose "Force version"
8 years 4 months ago #111998 by tecno
Hmmmm
LinuxCNC 2.7.13 has been released. All users are encouraged to upgrade. This version improves the documentation, fixes some old obscure bugs, and fixes yet another version-skew problem with TCL/Tk newer platforms.
Unfortunately I am without LAN for a week or so as I have to return my faulty Devolo plug set as one part is non functioning.
Will have to consider digging out the PC and bring it up here to do the down grading, if it helps ?
8 years 4 months ago #111999 by andypugh
The big question is whether it is worth downgrading just to prove whether the problem is with the LinuxCNC update.
I think you should try with a servo-period of 1000000 as a very quick experiment to see if that helps with the jogs.
[EMCMOT]SERVO_PERIOD
Time to create page: 0.434 seconds
