LinuxCNC on Linux Mint 19
7 years 9 months ago #124280 by spokes
Replied by spokes on topic LinuxCNC on Linux Mint 19
Ok. please hang with me as I muddle through this. I'm running linux mint 19.1 and following these instructions. Its a completely fresh install of mint, i've installed all the dependencies listed, but I'm getting the following error when trying to use the package installer "Error: Dependency is not satisfiable: linuxcnc-uspace (=1:2.8.0~pre1)" I'm a machinist by trade and a total linux noob so please help me out, I just want to make some chips on the mini mill i just built in the garage.
7 years 9 months ago - 7 years 9 months ago #124304 by BigJohnT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
Did you enable source code repositories in the Synaptic Package Manager?
Those are my instructions and I've built several Mint 19.1 drives with them so I know they work if followed exactly.
JT
Last edit: 7 years 9 months ago by BigJohnT.
7 years 9 months ago #124308 by spokes
So i did but it doesn't seem to work because click ok to update cache after enabling repositories and it pops up a dialog that says updating cache waiting for synaptic to exit and it just hangs there. I can't close synaptic but i can close the software sources but that closes the update cache. When i reopen everything it shows that the repositories are enabled. Is there a way to update the cache via terminal to by pass where it seems to hang?
7 years 9 months ago - 7 years 9 months ago #124309 by BigJohnT
sudo apt-get update
I should have put a note in there to not update the cache from Synaptic...
JT
7 years 9 months ago #124325 by spokes
OK. I wiped the whole mint install and started over. I realized I failed the kindergarten test and skipped the very first instruction I think because I thought thats what sudo apt-get update was taking care of. ( like i said total linux noob) rocking and rolling windows popped up that didn't before etc. i installed the dependencies, verified the installation and i got an error so went through the list again. same error, "error:cannot read debian/control no such file or directory" i tried reinstalling all the dependencies and i got the same error.
7 years 9 months ago - 7 years 9 months ago #124344 by BigJohnT
I have a fresh install of Linux Mint 19.1 and I'll build LinuxCNC and install it and verify the instructions.
Edit: I'm updating the instructions, I had one command out of order.
Sorry for the confusion.
JT
Time to create page: 0.135 seconds
