LinuxCNC on Linux Mint 19
- BigJohnT
- Thank you received: 994
03 Dec 2018 23:54 - 17 Jan 2019 13:02 #121786
by BigJohnT
LinuxCNC on Linux Mint 19 was created by BigJohnT
I've solved the issue with Linux Mint 19 and installing LinuxCNC.
The instructions are here:
gnipsel.com/linuxcnc/uspace/index.html
JT
JT
Last edit: 17 Jan 2019 13:02 by BigJohnT.
The following user(s) said Thank You: tivoi, MasterSpoon, dvn4life1972
- islander261
- Thank you received: 216
04 Dec 2018 16:03 #121813
by islander261
Replied by islander261 on topic LinuxCNC on Linux Mint 19
JT
Just another data point. Last week I built Master on Linux 64 bit 4.9.130-2 real time on my Debian 9/LDME-3 hybrid system and it worked fine. I didn't try to installed documentation.
- BigJohnT
04 Dec 2018 20:25 #121822
by BigJohnT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
Yea, I expect Debian to work fine as that it is the standard OS for LinuxCNC.
I built it on Linux Mint 18.3 this morning with full documents just fine. On Linux Mint 19 with/without documents I get the same error as above.
JT
JT
- Thank you received: 2181
05 Dec 2018 06:25 #121846
Replied by cmorley on topic LinuxCNC on Linux Mint 19
It's possible - I have a linuxcnc mint 19 - the kernel is older though.
It also locks up from time to time
I don't remember doing anything weird to do it.
I used the guide on the forum.
Chris M
Chris M
- Thank you received: 7488
05 Dec 2018 06:56 #121850
Replied by tommylight on topic LinuxCNC on Linux Mint 19
Good morning Chris, (or is it evening ??? I wonder.... )
Regarding locking,
- Linux Mint 18.3
- Linux HPi7 4.8.11-rt7 #1 SMP PREEMPT RT Sat May 5 10:50:35 CEST 2018 x86_64 x86_64 x86_64 GNU/Linux
- HP EliteDesk something or another
- AMD Radeon HD 8490
- Dual 23" monitors
Had 2 of the same PC
- one would hang completely as soon as i open Firefox with two windows and 10 to 15 tabs each
- the other hangs only if i open media player while everything else is opened ( audio or video ), the music or movie sound would continue to run but everything would halt.
Have no clue why this happens, i am using the latter for the last 4 months all day every day without any other issue.
Regarding locking,
- Linux Mint 18.3
- Dual 23" monitors
- newbynobi
- Thank you received: 394
07 Dec 2018 09:56 - 07 Dec 2018 10:01 #121994
by newbynobi
Replied by newbynobi on topic LinuxCNC on Linux Mint 19
I have build linuxcnc and glade 3.8.6 in a virtual machine with MINT 19 with success.
This are the steps I did:
Make our own linuxcnc system with MINT 19 (Tara)
first get the Image of Mint from
I choose the 64 bit release with Cinnamon
Install that release on your computer
My user is named linuxcnc and has the password linuxcnc,
please enter a password and select auto-login during setup!
so if you find in the following HowTo the user,
just replace with your name
with first reboot you will be asked to update your system,
please do so, update everything!
OK now your system is up to date,
Let's install the realtime preempt kernel
first we need to install some dependencies
check for "Fully Preemptible Kernel(RT)"
and do activate this option
Exit with save!
in the terminal now enter:
this will take a while, depending on your computer
go on with:
After that step, I was forced to edit /etc/default/grub
as the grub menu did not appear and I was not able to select the realtime kernel.
I hat to comment :
And then select the rt kernel
uname -a gave :
If this did work, you can delete the downloaded kernel packages in your home dir,
as they will occupy a lot of space and are not needed any more.
OK, lets get LinuxCNC from Source:
first need to install:
and than clone the github
as dpkg-checkbuilds needs assess to the source packages and as default the corresponding repositories are not enabled,
open synaptic from main menu, goto settings, packages and enable source code, check the corresponding box
close it and change to the terminal, enter
you should get:go on in the terminal
should give you somethink like:
just install all needed dependencies with:
I had to install additionally:
now go on withstill not running, missed
OK we may need also glade 3.8.6 to make our own glade panels, so we need to install that:
If you followed this HowTo, you should not have installed glade, otherwise uninstall the official one
as we need an older version of libgladeui,
get it from here:
and install with:get the source of glade 3.8.6
in the terminal enter:type
All OK?
Go On.
if that is also OK, we need to copy the hal widget glade catalog to the correct place.
backup the originals first
now copy/add the missing files to that dir with the following terminal commands
Now test in the terminal you did the commandjust enter
last is to make to start scripts:
first to start linuxcnc in rip mode:
just make a directory bin in your home folder and
add a file linuxcnc.sh with the following content
Make that file executable
On your desktop make a starter
Name = linuxCNC
Command = /home/linuxcnc/linuxcnc.sh
Commend = Start LinuxCNC
And check the box "Start in Terminal"
A icon to be used may be:
Click OK and try that one out
lets do another starter for glade:
add a file glade-3.sh with the following content to the created bin folder
Name = Glade-3
Command = /home/linuxcnc/glade-3.sh
Commend = Start Glade 3.8.6
A beautifull icon to be used may be:
Now be happy
https://linuxmint.com/download.phpI choose the 64 bit release with Cinnamon
sudo apt-get install build-essential kernel-package libncurses5-dev wget bzip2 libssl-dev
wget https://kernel.org/pub/linux/kernel/v4.x/linux-4.9.115.tar.xz
wget https://www.kernel.org/pub/linux/kernel/projects/rt/4.9/patch-4.9.115-rt93.patch.gz
tar -xpf linux-4.9.115.tar.xz
gunzip patch-4.9.115-rt93.patch.gz
cp patch-4.9.115-rt93.patch linux-4.9.115
cd linux-4.9.115
cat patch-4.9.115-rt93.patch | patch -p1
cp /boot/config-`uname -r` ./.config
make oldconfig
make menuconfigcheck for "Fully Preemptible Kernel(RT)"
Exit with save!
make -j8this will take a while, depending on your computer
go on with:
sudo make modules_install
sudo make installAfter that step, I was forced to edit /etc/default/grub
I hat to comment :
#GRUB_TIMEOUT_STYLE=hiddenAnd then select the rt kernel
uname -a gave :
Linux linuxcnc 4.9.115-rt93 #1 SMP PREEMPT RT Sat Nov 24 17:09:54 CET 2018 x86_64 x86_64 x86_64 GNU/LinuxIf this did work, you can delete the downloaded kernel packages in your home dir,
sudo apt-get install git git-gui gitkand than clone the github
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-devas dpkg-checkbuilds needs assess to the source packages and as default the corresponding repositories are not enabled,
sudo apt-get update
cd linuxcnc-dev/debian
./configure uspaceyou should get:
successfully configured for 'uspace-LinuxMint-18.2'-'uspace+xenomai'..cd ..
dpkg-checkbuilddepsshould give you somethink like:
dpkg-checkbuilddeps: Fehler: Nicht erfüllte Bauabhängigkeiten: debhelper (>= 6) dh-python libudev-dev libxenomai-dev tcl8.6-dev tk8.6-dev libreadline-gplv2-dev asciidoc (>= 8.5) dblatex (>= 0.2.12) dvipng graphviz groff inkscape python-lxml source-highlight texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended w3c-linkchecker python-dev python-tk libxmu-dev libglu1-mesa-dev libgl1-mesa-dev | libgl1-mesa-swx11-dev libgtk2.0-dev intltool libboost-python-dev libmodbus-dev (>= 3.0) libusb-1.0-0-dev yapps2just install all needed dependencies with:
sudo apt-get install debhelper dh-python libudev-dev libxenomai-dev tcl8.6-dev tk8.6-dev libreadline-gplv2-dev asciidoc dblatex dvipng graphviz groff inkscape python-lxml source-highlight texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended w3c-linkchecker python-dev python-tk libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libgtk2.0-dev intltool libboost-python-dev libmodbus-dev libusb-1.0-0-dev yapps2I had to install additionally:
sudo apt-get install bwidget
sudo apt-get install libtk-imgnow go on with
cd src
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcncsudo apt-get install python-gtkglext1
sudo apt-get install python-gtksourceview2
sudo apt-get install python-vteOK we may need also glade 3.8.6 to make our own glade panels, so we need to install that:
sudo apt-get remove gladesudo apt-get install intltool python-gtk2-dev libxml2-dev gtk-doc-tools gnome-doc-utils liblablgtk2-gnome-ocaml-dev libglade2-dev python-gtkglext1 itstoolget it from here:
https://packages.ubuntu.com/trusty/amd64/libgladeui-1-11/downloadand install with:
sudo dpkg --install /home/linuxcnc/Downloads/libgladeui-1-11_3.8.0-0ubuntu6_amd64.deb in the terminal enter:
wget ftp://ftp.gnome.org/pub/GNOME/sources/glade3/3.8/glade3-3.8.6.tar.xz
tar -xpf glade3-3.8.6.tar.xz
cd glade3-3.8.6
./configure
make
sudo make installglade-3All OK?
Go On.
sudo mkdir -p /usr/local/share/glade3/backup/catalogs
sudo mkdir -p /usr/local/share/glade3/backup/pixmaps
sudo cp /usr/local/share/glade3/catalogs/* /usr/local/share/glade3/backup/catalogs
sudo cp -r /usr/local/share/glade3/pixmaps/* /usr/local/share/glade3/backup/pixmapsnow copy/add the missing files to that dir with the following terminal commands
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.xml /usr/local/share/glade3/catalogs
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.png /usr/local/share/glade3/pixmapsNow test in the terminal you did the command
cd
cd linuxcnc-dev
. ./scripts/rip-environmentglade-3last is to make to start scripts:
#!/bin/bash
cd /home/linuxcnc/linuxcnc-dev
linuxcncMake that file executable
Name = linuxCNC
/home/linuxcnc/linuxcnc-dev/linuxcncicon.pngClick OK and try that one out
#!/bin/bash
glade-3Make that file executable
Name = Glade-3
/usr/share/icon/Mint-X/apps/48/glade-3.pngClick OK and try that one out
Now be happy
Last edit: 07 Dec 2018 10:01 by newbynobi.
The following user(s) said Thank You: BigJohnT, tommylight, rodw, islander261, johnmc1, snoozer77
07 Dec 2018 11:04 #121999
Did install Mint 19 with Mate yesterday, installed a pre compiled RT kernel ( compiled on Mint 18.1 a long time ago, works even on Debian stretch), downloaded the plasmac version of git made by Phillc, everything works till building a deb for Linuxcnc, that fails with complaints about missing some xml and pdf files.
- BigJohnT
11 Dec 2018 12:45 #122204
by BigJohnT
newbynobi that is some very good instructions. I'm currently running Linux Mint 18.3 with a much newer kernel.
JT
uname -a
Linux cave-mint18 4.19.1-rt3 #1 SMP PREEMPT RT Wed Dec 5 04:47:55 CST 2018 x86_64 x86_64 x86_64 GNU/LinuxJT
- newbynobi
12 Dec 2018 22:17 #122319
by newbynobi
Hallo John,
thanks for the kernel information, i will check on that and inform if the new kernel do work also with mint 19
Norbert
Norbert
- BigJohnT
08 Jan 2019 23:28 #123801
by BigJohnT
Well I solved the problems with Linux Mint 19.1 and playing around with the RTD stuff posted all the Uspace info I had
here
. Still need to check some items but everything should work.
JT
JT
The following user(s) said Thank You: KCJ, snoozer77
Time to create page: 3.911 seconds
