LinuxCNC on Linux Mint 19
- paulctan
03 May 2019 12:50 #132626
by paulctan
Replied by paulctan on topic LinuxCNC on Linux Mint 19
Realistically, that's basically it. You don't need to rebuild the kernel. I'm sticking with Mint because I'm used to Ubuntu, just to keep the same distro between my machines. Other than that, for someone unfamiliar with linux, kernel compilation takes time and a lot of step, so I would recommend the Debian way for people that aren't as familiar with linux.
- BigJohnT
- Thank you received: 994
04 May 2019 12:46 #132731
by BigJohnT
I'd have to ask which "original guide" as I've made so many. I currently use Debian 9 because:
I think QtPyVCP runs fine on Linux Mint 19 but I've not tried it.
JT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
Now that the Mate desktop is in Debian I just use Debian 9, much simpler.
gnipsel.com/linuxcnc/uspace/debian9-rt.html
gnipsel.com/linuxcnc/uspace/debian9-emc.html
JT
For the uneducated among us, is there a difference functionality wise between your original guide and using the debian9 guide you linked here ?
Using the original guide, apart from making the kernel taking ages it was pretty straight forward. I did maybe 1/2hr of stuff last night, told it to make the kernel and went to bed, spent another 1/2hr this morning and it was all done.
- I don't have to compile a kernel
- The Mate desktop is avaliable
- QtPyVCP runs without any issue on Debian 9
JT
- MasterSpoon
04 May 2019 14:20 #132738
by MasterSpoon
Replied by MasterSpoon on topic LinuxCNC on Linux Mint 19
Sorry should have been more specific
Was talking about this being the original guide
gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
Like I said I'm a Linux newbie, my google fu leads me to believe
This guide gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html uses Ubuntu Bionic as the package base
vs
This guide gnipsel.com/linuxcnc/uspace/debian9-rt.html uses Debian Stretch as the package base
Without diving too far into the Linux hole and getting distracted it appears that Ubuntu is aimed at being more user friendly. Myself, and I dare say others are looking at LinuxCNC to see if it's a viable alternative to either trying to keep old hardware alive to run Mach3 or shelling out for a Mach4 license.
If we ignore the install steps, is there likely to be any performance difference between Ubuntu Bionic vs Debian Stretch for someone that is only planning to use it for motion control ? Is one more / less likely to play nice with newer hardware ?
vs
- BigJohnT
04 May 2019 16:01 - 04 May 2019 16:03 #132746
by BigJohnT
The user friendly part is the Desktop environment, now that Linux Mint and Debian both have the Mate Desktop that part is pretty much is the same. Recent OS's of Ubuntu, Mint and Debian should all be the same for recent PC hardware. Even Ubuntu has a Mate variant now, lol. When I wrote the original guide I was not aware that Debian 9 had the Mate Desktop and my idea was to have every version in one place so people could choose without having to look all over the place.
The only reason I used Linux Mint and went thought the trouble of building a kernel is to get the Mate Desktop. I have one more machine to convert to Debian 9 in my shop and install QpPyVCP as my GUI. Working on my plasma now. My most favorite OS was Ubuntu 10.04 and the CHNC still runs that... until I get time to make a QtPyVCP GUI for it.
JT
JT
Last edit: 04 May 2019 16:03 by BigJohnT.
- InMyDarkestHour
- Visitor
04 May 2019 16:34 #132748
by InMyDarkestHour
Replied by InMyDarkestHour on topic LinuxCNC on Linux Mint 19
Debian with xfce desktop is going to be least resource hungry. This is what I have seen in my own testing.
If I was a new comer to Linux and wanting to switch from Mach to Linuxcnc I certainly wouldn’t be using anything but the Debian based distro made by the linuxcnc guys.
- Thank you received: 7496
05 May 2019 02:51 #132802
Replied by tommylight on topic LinuxCNC on Linux Mint 19
Since i did not see it mentioned, any of the versions of ready made Debian images with Linuxcnc that come with Xfce can be used also with MATE or any other desktop environment, Install as usual, open synaptics, find Mate and install.
Personally i do prefer Mate for a lot of reasons, and one of the reasons is it reminds me of Ubuntu 10.04 and it's Gnome, it has all the important things where they should be.
Also just as added info, if anyone is looking for a Lite distro, the only usable distro with Mate or any other desktop that is really lite is Porteus. There are plenty of lite versions that are not light at all and there are really light versions like some puppy's and Damn small linux that are fully usable distros at 50MB or so and can be run on very old hardware.
Porteus has still versions for 486 computers.
- InMyDarkestHour
- Visitor
05 May 2019 06:45 #132811
by InMyDarkestHour
Have you tried the whisker menu plugin under xfce ?
Quick screenshot forum.linuxcnc.org/9-installing-linuxcnc...t-19?start=50#132398
05 May 2019 22:14 #132879
Not yet. For the older PC's i use Debian Stretch netinstall iso and add the mate or xfce as needed, it is much snappier than Mint and a bit better latency.
- InMyDarkestHour
- Visitor
05 May 2019 22:31 #132883
by InMyDarkestHour
I rolled a custom iso, based on the netinstall iso, for installation, included all settings and extra software as needed, saves bandwidth.
That's pretty much what I've seen, debian does seem a little snappier.
- JD1
06 May 2019 02:02 #132896
by JD1
Thanks I tried this and it worked smoothly.
Replied by JD1 on topic LinuxCNC on Linux Mint 19
If you have your heart set on Mint, Why not try LMDE3 (it is based off Stretch).
Download and install that, then using Synaptic install "linux-image-4.9.0-4-rt" (686 or AMD64 which ever suits your PC), then reboot into the new kernel and add the Linuxcnc and Linuxcnc's buildbot repos for Stretch and install Linuxcnc. (all using Synaptic) There should be no special hoops to jump through.
Time to create page: 1.146 seconds
