LinuxCNC on Linux Mint 19
- AnnoyingMutt
- Visitor
15 Apr 2019 04:14 - 15 Apr 2019 04:18 #130884
by AnnoyingMutt
Meh
Replied by AnnoyingMutt on topic LinuxCNC on Linux Mint 19
what is u space? - I only followed the instructions ... if upsace was included in the instructions, then I would have configured uspace?
Meh
Last edit: 15 Apr 2019 04:18 by AnnoyingMutt.
- jackotool
15 Apr 2019 04:39 #130886
by jackotool
Replied by jackotool on topic LinuxCNC on Linux Mint 19
debian/configure uspace
I did this if this is what you mean
- AnnoyingMutt
- Visitor
15 Apr 2019 06:00 #130887
by AnnoyingMutt
what kernel are you running ?
- pl7i92
- Thank you received: 358
15 Apr 2019 06:26 #130889
by pl7i92
Replied by pl7i92 on topic LinuxCNC on Linux Mint 19
can you post the output of
uname -a
please
uname -a
please
- BigJohnT
- Thank you received: 994
17 Apr 2019 09:58 #131049
by BigJohnT
Did you do step 1 first? gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
JT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
Hello,
Thanks for the instructions - I have followed carefully -but when i get to "dpkg-checkbuilddeps"
I get error message "dpkg-checkbuilddeps: error: Unmet build dependencies: rtai-modules-3.4-9-rtai-686-pae intltool" How do I add this dependency? I thought it was already there?
gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
Any help appreciated ...
Many thanks,
Jack
JT
- paulctan
25 Apr 2019 19:54 #131879
by paulctan
Replied by paulctan on topic LinuxCNC on Linux Mint 19
I can confirm that as of today, 25-Apr-2019, the instructions provided by BigJohnT worked perfectly. The only change I made was to run 'make -j4' instead of just 'make'. Speeds up the kernel build considerably.
Great Job BigJohnT!
I can also confirm that attempting to do the same instructions using just Ubuntu 18.04 LTS fails, so Mint is adding some other packages that are needed by LinuxCNC.
One quick question though: Is there any advantage to building the latest Preempt_RT kernel instead of the .1 version? I think the latest build with _RT is .31.
Great Job BigJohnT!
- BigJohnT
26 Apr 2019 00:11 #131908
by BigJohnT
I assume as they fix things it's better to use the latest version but you know what assume means lol.
JT
JT
- Thank you received: 7496
26 Apr 2019 15:19 #131975
Replied by tommylight on topic LinuxCNC on Linux Mint 19
Assumption = the mother of all f###ups !
Very true.
Very true.
- JD1
29 Apr 2019 23:51 #132321
by JD1
Replied by JD1 on topic LinuxCNC on Linux Mint 19
Thank you for the instructions.
I currently have Linux Mint 19.1 installed – and want to install linuxcnc.
I followed carefully but my computer fails to restart after finishing step 1. gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
System Info
Operating System Linux Mint 19.1 Cinnamon
Cinnamon Version 4.0.10
Linux Kernel 4.15.0-48-generic
Processor Intel Core i5-2500 CPU @ 3.30GHz x 4
Memory 13.6 GiB
Hard Drive 76.4 GB
Graphics Card Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller
Any help is appreciated
System Info
Memory 13.6 GiB
Hard Drive 76.4 GB
- AnnoyingMutt
- Visitor
30 Apr 2019 05:12 #132325
by AnnoyingMutt
You will have to explain what actually happens, "fails to restart" is pretty vague.
Can you still boot using the old kernel....it may be under the Advanced options menu item.
Time to create page: 1.215 seconds
