LinuxCNC on Linux Mint 19
7 years 10 months ago #121999 by tommylight
Did install Mint 19 with Mate yesterday, installed a pre compiled RT kernel ( compiled on Mint 18.1 a long time ago, works even on Debian stretch), downloaded the plasmac version of git made by Phillc, everything works till building a deb for Linuxcnc, that fails with complaints about missing some xml and pdf files.
7 years 10 months ago #122204 by BigJohnT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
newbynobi that is some very good instructions. I'm currently running Linux Mint 18.3 with a much newer kernel.
uname -a Linux cave-mint18 4.19.1-rt3 #1 SMP PREEMPT RT Wed Dec 5 04:47:55 CST 2018 x86_64 x86_64 x86_64 GNU/Linux
JT
7 years 10 months ago #122319 by newbynobi
Replied by newbynobi on topic LinuxCNC on Linux Mint 19
Hallo John,
thanks for the kernel information, i will check on that and inform if the new kernel do work also with mint 19
Norbert
7 years 9 months ago #123801 by BigJohnT
Well I solved the problems with Linux Mint 19.1 and playing around with the RTD stuff posted all the Uspace info I had here . Still need to check some items but everything should work.
JT
The following user(s) said Thank You: KCJ, snoozer77
7 years 9 months ago #124042 by DustMaxrr
Replied by DustMaxrr on topic LinuxCNC on Linux Mint 19
Thank you John ! I like using LinuxMint much better.
I started with LinuxMint 18.3 MATE(32) instead of (64), and exactly followed your link on your page for installing rt kernel.
Seems the kernel is there, but says installation failed, and now my boot space is 100% full (rt archive image is 407mb).
Should the installation on (32) work the same as the (64)?
Any suggestions before I start from scratch again?
Ron
7 years 9 months ago #124067 by DustMaxrr
Sorry for my previous post. I just answered my own question.
Sometimes you look but you can't see.
Ron
Time to create page: 0.361 seconds
