LinuxCNC on Linux Mint 19
7 years 9 months ago #124502 by JohnnyCNC
Replied by JohnnyCNC on topic LinuxCNC on Linux Mint 19
I tried to do the Linux Mint 19.1 install with the RT kernel following these instructions. The Linux Mint 19.1 64 bit install was uneventful and seemed to work fine. Then I started with instructions referenced in the earlier posts in this thread. I saw some warnings go by that I had no idea what to do about them. Compiling the kernel took about 10 hours so I was able to do a little more than take a nap and have a cup of coffee LOL. I'm not going to spend time figuring out why it went wrong I'm just going to start over. The instructions looked great and I'm sure it's something I did or didn't do. I use Visual Studio and work in C# daily at my job so I am just trying do this install and build the kernel as a means to and end. Not for the fun of it, Machining is the fun part. I have a J1800 BAT-1 motherboard with a Mesa 6i25+7i76 currently running Axis and all is well. Now I want to get a touch screen and give gmocappy a try while I wait for the BrendaEM interface to come out. So I thought I would also upgrade to Mint because I would like to have a long term release installed with some years still ahead of it and I have heard that I may have better luck with a touch screen using a more recent version of Linux. That brings me to a couple of questions. I think I should be looking at the RTAI rather than the preempt since I am running a 6i25? Or can I run either? Is there any advantage of one over the other? Is there anywhere I can get a prebuilt RTAI kernel? Thanks
7 years 9 months ago #124847 by DustMaxrr
Replied by DustMaxrr on topic LinuxCNC on Linux Mint 19
JT
Followed your instruction, now have mint 18.3 running 4.19.1-rt3.
Had an issue with the 8254 timer error, but "noapic" got me up and running.
Thanks for the info.
7 years 9 months ago #125338 by DustMaxrr
JT
Do your instructions for linxcnc on LM19.1 include support for mesa cards (hostmot2) ?
Ron
7 years 9 months ago #125437 by BigJohnT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 19
Yes after installing Linux Mint you build the RT Preempt kernel then you add LinuxCNC and if your using a Mesa Ethernet card there are instructions to setup the NIC for that.
JT
The following user(s) said Thank You: tivoi
7 years 8 months ago #127163 by jeroenkort
hi BigJohnT
I followed your instructions and the kernel was build without any errors.
but it dose not boot in to it
if I select the recovery option in grub menu it hangs included a photo of it
I tried to do a fresh install again and same result
what is going wrong here?
the computer got core duo 2 processor and runs 64 mint 19
7 years 7 months ago #127500 by pl7i92
Replied by pl7i92 on topic LinuxCNC on Linux Mint 19
He Shoudt make a Wikipedia Documentation out of this
at least inside the Forum make it sticky
Time to create page: 0.393 seconds
