LinuxCNC Uspace
- phoenix
28 May 2019 05:50 #135123
by phoenix
Replied by phoenix on topic LinuxCNC Uspace
sir did you mean we cant use real time kernal on debian stretch for building linuxcnc
28 May 2019 22:40 #135212
Replied by andypugh on topic LinuxCNC Uspace
You can use the preempt-rt kernel (that is included on the LinuxCNC Stretch ISO) or you can install the kernel package on a plain install:
If you go to the Synaptic package manager you will find it with a search for "realtime"
This is the package for Jessie (which I happen to have open)
linux-image-4.9-rt-amd64
"Linux for 64-bit PCs (meta-package), PREEMPT_RT"
So you can just install that from the package manager (the kernel number will be different)
The following user(s) said Thank You: Nico2017, phoenix
- gmarconi2
- Thank you received: 5
11 Jun 2019 19:19 #136641
by gmarconi2
Replied by gmarconi2 on topic LinuxCNC Uspace
I installed linuxcnc on lubuntu 19.04 as instructed, I expected that in the programs there was boot linuxcnc, there is an emc directory, now how do I have to do to start the linuxcnc suite
11 Jun 2019 19:24 #136642
Is there a "CNC" section in the applications menu?
Alterantively, try "linuxcnc" from the command prompt.
- gmarconi2
11 Jun 2019 20:10 #136652
by gmarconi2
thanks for the answer probably preempt RT is installed and compiled linuxcnc no
uname -a
linux giampiero-pc 5.0.19 rt 11 # 1 SMP PREEMPT RT
These are the instructions I have run
git clone github.com/LinuxCNC/linuxcnc.git emc
sudo apt install -y devscripts build-essential
sudo apt update
uname -a
sudo apt update
- gmarconi2
11 Jun 2019 20:25 #136653
by gmarconi2
giampiero @ giampiero-pc: ~ / emc $ linuxcnc
Command «linuxcnc» not found, was meant:
command "linuxvnc" from deb linuxvnc (0.9.10-2build1)
Try: sudo apt install <deb name>
giampiero @ giampiero-pc: ~ / $ emc
- BigJohnT
- Thank you received: 994
11 Jun 2019 20:27 #136654
by BigJohnT
Replied by BigJohnT on topic LinuxCNC Uspace
There is much more to do to get LinuxCNC installed.
This page is not finished yet.
gnipsel.com/linuxcnc/uspace/lubuntu19-emc.html
However the instructions on this page can be used.
gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
I'll see if I can finish that in the morning.
JT
JT
- AgentWD40
- Thank you received: 96
12 Jun 2019 01:23 #136681
by AgentWD40
I could very well be asking this in the wrong place. Apologies in advance.
I've used your instructions to attempt to install the kernel for mint 19.1
gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
The new grub loads and I select the new kernel 4.19.1-rt3 and booting stops with the following screen
I'm dead in the water here. Any idea where I went wrong?
Replied by AgentWD40 on topic LinuxCNC Uspace
- pl7i92
- Thank you received: 358
12 Jun 2019 06:07 #136697
by pl7i92
Replied by pl7i92 on topic LinuxCNC Uspace
did you install the mint 19 distro first or did you only load the kernel into debian9
12 Jun 2019 09:46 #136707
Does the machine still boot with the earlier kernel selected?
What was that kernel?
Have you tried running a pre-compiled kernel package?
Does Mint find any such realtime kernels in the package manager? If not then you could try adding the debian 9 repositories to see what you can find.
The kernel panic hints that something went wrong during your kernel compile.
Out of interest, how long did you have to wait after the "make" command, and were there any error messages generated?
Time to create page: 0.186 seconds
