LinuxCNC Uspace
- AgentWD40
- Thank you received: 96
12 Jun 2019 13:57 - 12 Jun 2019 13:59 #136728
by AgentWD40
I want to say I didn't even see options for the old kernel. I'll report back on this asap.
Honestly I didn't even think to look in the repos for a precompiled kernel. It didn't occur to me that would be an option. Does anyone happen to know if the rt-preempt kernel is available in the mint 19.1 repos? If I can quickly get this install repaired I'll look for it, otherwise I'll just go back to a linuxcnc iso.
I don't know. From previous experience I didn't bother waiting around to find out. I went to bed and when I came back there were no error messages on the terminal at that time.
I feel like you've asked lots of good questions and I've had zero helpful answers. I'll explore grub more thoroughly and see if another kernel will load and report back.
Replied by AgentWD40 on topic LinuxCNC Uspace
Does the machine still boot with the earlier kernel selected?
What was that kernel?
Have you tried running a pre-compiled kernel package?
Does Mint find any such realtime kernels in the package manager? If not then you could try adding the debian 9 repositories to see what you can find.
The kernel panic hints that something went wrong during your kernel compile.
Out of interest, how long did you have to wait after the "make" command, and were there any error messages generated?
Last edit: 12 Jun 2019 13:59 by AgentWD40.
- bevins
- Thank you received: 338
12 Jun 2019 14:38 - 12 Jun 2019 14:45 #136734
by bevins
Replied by bevins on topic LinuxCNC Uspace
Linuxmint 19.1 when compiling now compiles and installs all modules and keeps symbols making the image way too big so it cant boot.
You have to strip the symbols and compile it so just the modules required. check the image compared to the original, it will probably be like 10 times bigger.
I tried all kinds of stuff to fix it and couldn't get it to compile small enough.
So I installed debian 9. it has preempt RT kernel in the repo. But this has watchdog reboot issue.
Last edit: 12 Jun 2019 14:45 by bevins.
The following user(s) said Thank You: AgentWD40
- bevins
12 Jun 2019 14:41 #136735
by bevins
Would be nice and very appreciative if some kernel guru on here and help us on how to configure so the kernel is a decent size so grub will load it.
- AgentWD40
12 Jun 2019 14:45 #136736
by AgentWD40
I'm curious, did you try to install the preempt kernel from the debian repo into your mint installation? I gather that was what andypugh was suggesting here "Does Mint find any such realtime kernels in the package manager? If not then you could try adding the debian 9 repositories to see what you can find."
- bevins
12 Jun 2019 14:47 - 12 Jun 2019 14:48 #136737
by bevins
I didn't try that, I needed to get a system up and running. I may try adding debian repo to linux mint, I'm not sure how well that will work though.
Last edit: 12 Jun 2019 14:48 by bevins.
- bevins
12 Jun 2019 14:54 #136738
by bevins
This should strip the symbols and create an imagel small enough to be usable.
SHW@SHW:/tmp# cd /lib/modules/<new_kernel>
SHW@SHW:/tmp# find . -name *.ko -exec strip --strip-unneeded {} +Please Log in or Create an account to join the conversation.
12 Jun 2019 15:04 #136740
Replied by andypugh on topic LinuxCNC Uspace
It seems like this should be a config option. "Enable loadable Module Support" or similar?
- bevins
12 Jun 2019 15:20 #136746
by bevins
Its loading the modules. its loading all the modules and all the symbols for developers. This is my take on it.
When I have a few hours, I will try stripping them with that command and see if it works.
- Thank you received: 5334
12 Jun 2019 16:58 #136762
Replied by PCW on topic LinuxCNC Uspace
Newer kernels that I have built have huge initrd images (nearly 400 mb)
but the zipped kernel size is still about 8M max which does not
seem to cause an issue. Is it possible that you have a separate /boot partition
that is out of space?
- AgentWD40
12 Jun 2019 17:15 - 12 Jun 2019 17:19 #136766
by AgentWD40
I manually configured my partitions at setup but didn't create a separate boot partition. /boot lives on the main partition.
I've just installed Mint 19.1 on a virtual machine, added the debian stretch repo, and installed debian's rt kernel. After some finangling in the grub customizer I've successfully loaded mint 19.1 with the 4.9.0-9-rt-amd64 kernel as confimred by uname -a.
Of course it's untested, just wanted to let you all know.
Is the 4.9 kernel suitable? John's instructions are for the 4.19 kernel.
And to answer a previous question from andy, the default kernel right now on mint 19.1 appears to be 4.15. Rather, that's what's included on a fresh install. I hadn't bothered with apt-get upgrade yet.
Last edit: 12 Jun 2019 17:19 by AgentWD40.
Time to create page: 0.281 seconds
