(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- Topic Author
- Online
- Thank you received: 5926
22 Apr 2020 19:58 #165151
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Did you get the GRUB menu?
You have to chose the other kernel there.
- Topic Author
- Online
22 Apr 2020 20:01 #165152
In a terminal:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Start grub-customizer from the menu, select the 4.14.28-rt23-kona-rt and use the UP arrow to move it to the top of the list, save, exit.
Reboot.
sudo apt-get update
Reboot.
22 Apr 2020 20:25 #165155
by Nate
Replied by Nate on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
no i did not get the grub menu
- BeagleBrainz
- User is blocked
- Thank you received: 570
22 Apr 2020 23:44 - 22 Apr 2020 23:47 #165165
by BeagleBrainz
Replied by BeagleBrainz on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
As easier solution without having to install grub customiser
Edit as superuser or root /etc/default/grub
eg:
At the top of the file
Change this line from
GRUB_DEFAULT=0
to
GRUB_DEFAULT=saved
Add this line
GRUB_SAVEDEFAULT=true
Edit\add these lines
#GRUB_HIDDEN_TIMEOUT=0
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
Edit\add this line
GRUB_DISABLE_SUBMENU=y
Then we need to update grub
This will do the following:
Show the grub menu & will boot the default choice after 10 seconds
Show all the kernels without a submenu such as "Advanced options"
Save the last selected kernel and make that the default kernel
References:
www.gnu.org/software/grub/manual/grub/ht...e-configuration.html
askubuntu.com/questions/148662/how-to-ge...remember-last-choice
This is the example of what I have, do not copy & paste but use as a reference:
eg:
sudo nano /etc/default/grub
GRUB_DEFAULT=0
to
GRUB_DEFAULT=saved
Add this line
GRUB_TIMEOUT=10
Edit\add this line
sudo update-grub
References:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
Last edit: 22 Apr 2020 23:47 by BeagleBrainz.
23 Apr 2020 02:12 #165177
by Nate
This is the website I have been trying to use gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html and I now have the first issue I sent you figured out from what you sent but now I get to this spot git clone github.com/LinuxCNC/linuxcnc.git emc and it shows link invalid
- BeagleBrainz
- User is blocked
23 Apr 2020 02:43 - 23 Apr 2020 02:45 #165178
by BeagleBrainz
You need to type in the commands exactly as presented
git clone https://github.com/LinuxCNC/linuxcnc.git
Last edit: 23 Apr 2020 02:45 by BeagleBrainz.
24 Apr 2020 02:53 #165345
by Nate
Quick question my computer I am using has an intel dose that change what files I should be installing?
- BeagleBrainz
- User is blocked
24 Apr 2020 04:15 #165347
by BeagleBrainz
In regards to what files ?
24 Apr 2020 05:32 #165355
by Nate
I would have to go back and check I just remember some of the links on the step by step I have been fallowing are listed as ...... amd64
- BeagleBrainz
- User is blocked
24 Apr 2020 06:18 #165357
by BeagleBrainz
amd64 will work for intel 64 bit
Time to create page: 0.348 seconds
