(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
22 Apr 2020 19:58 #165151 by tommylight
Did you get the GRUB menu?
You have to chose the other kernel there.
  • Moderator
  • Moderator
22 Apr 2020 20:01 #165152 by tommylight
In a terminal:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Start grub-customizer from the menu, select the 4.14.28-rt23-kona-rt and use the UP arrow to move it to the top of the list, save, exit.
Reboot.
22 Apr 2020 20:25 #165155 by Nate
no i did not get the grub menu
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
22 Apr 2020 23:44 - 22 Apr 2020 23:47 #165165 by BeagleBrainz
As easier solution without having to install grub customiser
Edit as superuser or root /etc/default/grub
eg:
sudo nano /etc/default/grub
At the top of the file
Change this line from
GRUB_DEFAULT=0
to
GRUB_DEFAULT=saved
Add this line
GRUB_SAVEDEFAULT=true
Edit\add these lines
#GRUB_HIDDEN_TIMEOUT=0
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
Edit\add this line
GRUB_DISABLE_SUBMENU=y
Then we need to update grub
sudo update-grub
This will do the following:
Show the grub menu & will boot the default choice after 10 seconds
Show all the kernels without a submenu such as "Advanced options"
Save the last selected kernel and make that the default kernel
References:
www.gnu.org/software/grub/manual/grub/ht...e-configuration.html
askubuntu.com/questions/148662/how-to-ge...remember-last-choice
This is the example of what I have, do not copy & paste but use as a reference:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
Last edit: 22 Apr 2020 23:47 by BeagleBrainz.
23 Apr 2020 02:12 #165177 by Nate
This is the website I have been trying to use gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html and I now have the first issue I sent you figured out from what you sent but now I get to this spot git clone github.com/LinuxCNC/linuxcnc.git emc and it shows link invalid
  • BeagleBrainz
  • Visitor
  • Visitor
23 Apr 2020 02:43 - 23 Apr 2020 02:45 #165178 by BeagleBrainz
You need to type in the commands exactly as presented
git clone https://github.com/LinuxCNC/linuxcnc.git
Last edit: 23 Apr 2020 02:45 by BeagleBrainz.
24 Apr 2020 02:53 #165345 by Nate
Quick question my computer I am using has an intel dose that change what files I should be installing?
  • BeagleBrainz
  • Visitor
  • Visitor
24 Apr 2020 04:15 #165347 by BeagleBrainz
In regards to what files ?
24 Apr 2020 05:32 #165355 by Nate
I would have to go back and check I just remember some of the links on the step by step I have been fallowing are listed as ...... amd64
  • BeagleBrainz
  • Visitor
  • Visitor
24 Apr 2020 06:18 #165357 by BeagleBrainz
amd64 will work for intel 64 bit
Time to create page: 0.738 seconds
