(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- dvn4life1972
- Thank you received: 168
26 Jul 2020 21:06 #175975
by dvn4life1972
Replied by dvn4life1972 on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
26 Jul 2020 21:11 #175976
by riversvic
Replied by riversvic on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
tommy,
I'm trying a second computer, it continues to boot in 5.4 instead of 4.9. I moved 4.9 to the top in the grub customizer, that didn't work. I removed 5.4 in customizer and it continues to boot in 5.4.
- Topic Author
- Thank you received: 5928
26 Jul 2020 21:48 #175980
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
That will work, but 5.4 has a bit worse latency.
Did you try the config ?
- Topic Author
26 Jul 2020 21:50 #175981
And save it ..
Did you move it to the absolute top, not the top of the sub menu ?tommy,
And save it ..
The following user(s) said Thank You: riversvic
26 Jul 2020 21:57 #175983
by riversvic
That was it! thank you
- Topic Author
26 Jul 2020 22:00 #175984
You are welcomed, always.
The following user(s) said Thank You: bevins
07 Aug 2020 16:08 #177629
by bevins
Replied by bevins on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Thanks Tommy,
LinuxMint 19.3 installed with linuxcnc master......
Easiest install to date....
- Topic Author
07 Aug 2020 17:28 #177633
You are welcomed.
26 Aug 2020 20:32 #179577
by aparecido
Replied by aparecido on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I am testing Mint 19.3 following the tutorial in the first post, I checked the kernel and it is the same as in the initial post of the topic.
IPM31 v1.03 motherboard (Pcware / Pegatron) with onboard video
Core2duo E7500 2.93GHz-FSB 1066Mhz-L2 cache 3MB
1GB Kingston DDR2
Hd sata
I opened several programs and some windows with glxgears, the Jitter is around 40000ns and then jumps to 166640ns and stays at that value.
What can I do to lower the jitter value?
Thank you.
1GB Kingston DDR2
Hd sata
Thank you.
- Topic Author
26 Aug 2020 20:39 #179580
Add more memory, 4GB works fine, sometimes even 2GB are ok.
Time to create page: 0.119 seconds
