(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
09 Jan 2021 15:42 #194594 by tommylight
Glad to see this topic at the top of the Installing Linuxcnc page
I removed it after the release of the official 2.8, was not aware that it was used so much ! :)
The following user(s) said Thank You: rodw, my1987toyota
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
10 Jan 2021 10:08 #194699 by rodw
Thanks for making it a Sticky Tommy.
27 Jan 2021 17:23 - 27 Jan 2021 17:27 #196785 by bevins
Are the linux headers available for this rt kernel?
I need to compile a wifi module and cant get the right headers.
Linux linux-test 4.9.0-13-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.228-1 (2020-07-05) x86_64 x86_64 x86_64 GNU/Linux
Last edit: 27 Jan 2021 17:27 by bevins.
  • Moderator
  • Moderator
27 Jan 2021 17:33 #196787 by tommylight
ftp.us.debian.org/debian/pool/main/l/lin..._4.9.228-1_amd64.deb
Might need other packages, so here is the place to look for them:
debian.pkgs.org/9/debian-main-amd64/linu...228-1_amd64.deb.html
The link is down in the download section, double click on the link, right click above it and select "open link" from the context menu.
The following user(s) said Thank You: bevins
27 Jan 2021 17:33 - 27 Jan 2021 17:58 #196788 by bevins
I cant get a download from there and cannot install the .deb.
Last edit: 27 Jan 2021 17:58 by bevins.
27 Jan 2021 18:00 - 27 Jan 2021 18:04 #196791 by bevins
Actually I am trying to get the dependencies satisfied. That is not working.
I got them installed. Thanks
Last edit: 27 Jan 2021 18:04 by bevins.
  • Moderator
  • Moderator
27 Jan 2021 18:07 #196792 by tommylight
forum.linuxcnc.org/9-installing-linuxcnc...-nearly-easy-install
Check the "spoiler" part, probably will need all those.
Might have messed up the order, but double clicking on a file will open gdebi and it will complain about the missing package so install the mentioned package, and so on.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
04 Jun 2021 02:47 #211121 by BeagleBrainz
Hi Tommy,
Just had a play around with my last ISO in a VM.
Removed beaglebrainz.net form apt.
Added the linuxcnc repo.
Installed the latest linuxcnc, open axis and seemed ok.
The only extra that was installed was libboost.
Dunno if this is an easier option, no need to install the kernel nor grub customiser.
ISO is still on my Google drive, has been for a while now.
drive.google.com/file/d/1d7IEscVlyWoNZQe...s4D/view?usp=sharing
  • Moderator
  • Moderator
04 Jun 2021 11:34 #211145 by tommylight
No promises, but i will try to test it as soon as i can.
Spent nearly 4 hours last night gathering pictures and a PDF as i am helping retrofit a machine in France, so slept at 5, woke up at 11, trying to find my brain with help from coffee, and both of my shops are still closed at 1:30 PM!
Damn, i need 70 hour days ! :)
  • BeagleBrainz
  • Visitor
  • Visitor
04 Jun 2021 11:39 #211148 by BeagleBrainz
Fly us over and I'll come help......hahahaha
Time to create page: 0.148 seconds
