(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
05 Jun 2021 08:18 #211200 by rodw
Fly us over and I'll come help......hahahaha
They'll never let you back in so be careful!
29 Jun 2021 13:47 #213236 by aparecido
I'm having trouble machining on my CNC with Mint 19.3 and Linuxcnc 2.8.0, can I post what's happening here or open a new topic?
I'm lost on where to post here on the forum to get help, apparently the machine loses pace at times and from what I've noticed/tested, it's not a mechanical problem.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
29 Jun 2021 13:59 #213238 by BeagleBrainz
A new topic in the General area would be the best place to start.
Remember to give your PC specs, your OS, as not all may have read this thread and the hardware you are using Mesa card or parallel port.
Including you Hal and ini files to begin will save time.
A description of your machine, eg steppers or servos ball screw or plain lead screws and the like.
And finally a good description of the issue, any photos that may highlight the issue.
Be prepared for a few other questions.
And hopefully before you know it you’ll be making chips.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
04 Jul 2021 00:26 #213626 by tommylight
Updated the how to to use the Buster LinuxCNC repo since Stretch is not being built any more, requires downloading and installing additional 5 files.
The following user(s) said Thank You: JohnnyCNC
  • Moderator
  • Moderator
21 Jul 2021 23:47 #215535 by tommylight
Added development dependencies or dependency as only one is required.
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
29 Jul 2021 14:05 #216221 by mjones@welfab.ca
Hi How are things. I installed Linux Mint 19.3 as recently advised, and copied and pasted all the lines on page one of this topic.
Mint 19.3 installs quite well, no errors, both networks are up and running, but after reboot Linuxcnc still doesn't seem to be on the system. I can't find a link anywhere. should i try doing the copy past all the lines again.
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
29 Jul 2021 14:28 #216225 by mjones@welfab.ca
I apologize, I cound linuxcnc, I just searched linuxcnc in the menu search bar and realized that it opens to favorits, and needs to be set to all programs.
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
29 Jul 2021 14:59 #216231 by mjones@welfab.ca
Ok another question. I found the linuxcnc tried doing a pnc.config and it said
You have no hostmot2 firmware downloaded in folder:
/lib/firmware/hm2/
PNCconf will use internal firmware data
I tried finding hostmot2 in the package manager and its not there. so i need to know where to find the hostmot2 package and how to install it.
Any ideas?
  • Moderator
  • Moderator
30 Jul 2021 01:49 #216290 by tommylight
That is just a warning and can be safely ignored, no need for it except if using older Mesa boards.
31 Jul 2021 11:29 #216443 by daiman444
an attempt to add a repository "sudo apt-add-repository 'deb buildbot.linuxcnc.org/ buster 2.8-rtpreempt'" gives an error: Repository already exists.
all suggested keys have been tried((
Time to create page: 0.651 seconds
