(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- Thank you received: 7456
Do not change the title of the topic when replying to it, please.
Had a shock when i saw a title i could not recognize started by me !!!
- phillc54
- Thank you received: 2100
It would be nice if that could be prevented...WARNING:
- BeagleBrainz
- Visitor
I can see the subject box, but wow changing a title doesn't seem right.
Now i have to edit the original post to set it back, again!
I agree that this should be prevented, it causes a mess for searching with the added load on the server when adding another copy of the same topic to the database.
- Clive S
- Thank you received: 486
Files now available, as usual tested in Vbox
md5: 86 bytes (86 bytes)
drive.google.com/open?id=1jcSdgUkSubGNo8oRt_acU_0sjqCFJZyN
iso: 2.3 GB (2340421632 bytes):
drive.google.com/open?id=17f4FhtF5hayFpumpNHrGFyJ0OQlRb9aT
Enjoy
Ok I have put the above on a stick using Win32DiskImager everything went to plan and just worked.
Q. What is the difference between the two iso's . ie the one above and the one from the 11th LinuxMint-19.2-LCNC-2.9-rt-4.16.12-kona-amd64
Thanks again for the hard work you are putting into this.
This one has working QTVCP already installed.Q. What is the difference between the two iso's . ie the one above and the one from the 11th LinuxMint-19.2-LCNC-2.9-rt-4.16.12-kona-amd64
- BeagleBrainz
- Visitor
Next one, hopefully, will be a RTAI version. Had some issues with Andy's test linuxcnc packages relating to qtvcp designer. Posted up on the thread to see if there's some I screwed up.
Am currently building Linuxcnc 2.9 rtai packages and will see how it goes.
Once again big thanks to all who have downloaded the images and given them a twirl. Very much appreciated.
Cheers
Rob
- BeagleBrainz
- Visitor
Should have the RTAI done tomorrow morning, finished compiling the 2.9 RTAI Linuxcnc packages, qtvcp designer runs ok.
Kinda glad I've setup a local repo for the packages, saves having to wait to get packages off the net.
Wonder if it's worth doing an XFCE version...............
