First Time Builder - Stuck
6 years 9 months ago #155375 by phillc54
Replied by phillc54 on topic First Time Builder - Stuck
dzawacki wrote: When I follow the instructions on the buildbot page for upgrading to 2.8, I get to the final step
sudo apt-get install linuxcnc
and I'm told I already have the latest version.
That seems to indicate that you don't have the repositories set correctly.
Open Synaptic Package Manager, Search for linuxcnc and remove it if installed.
Go to Settings - Repositories and make sure the only active entries for linuxcnc are:
deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt deb-src http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
If you made any changes then click Reload to update the package information.
Search for linuxcnc and it should find linuxcnc-uspace, that is the one to install or from terminal you could enter:
sudo apt-get install linuxcnc-uspace
It may be wothwhile before you do all this to open a terminal and enter:
uname -a
and make sure there is "PREEMPT RT" somewhere in the reply to confirm you have an appropriate kernel.
6 years 9 months ago #155379 by dzawacki
Replied by dzawacki on topic First Time Builder - Stuck
I ran
uname -a
and got:
Linux debian 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
Running
after updating the sources in the Synaptic Package Manager gives me the following output:
danny@debian:~$ sudo apt-get install linuxcnc-uspace [sudo] password for danny: Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: linuxcnc-uspace : Depends: libboost-python1.62.0 but it is not installable Depends: libc6 (>= 2.15) but 2.13-38+deb7u12 is to be installed Depends: libfontconfig1 (>= 2.11) but 2.9.0-7.1+deb7u1 is to be installed Depends: libpango-1.0-0 (>= 1.14.0) but it is not installable Depends: libpangocairo-1.0-0 (>= 1.14.0) but it is not installable Depends: libpangoft2-1.0-0 (>= 1.14.0) but it is not installable Depends: libstdc++6 (>= 5.2) but 4.7.2-5 is to be installed Depends: libtk8.6 (>= 8.6.0) but it is not installable Depends: libudev1 (>= 183) but it is not installable Depends: tcl8.6 but it is not installable Depends: tk8.6 but it is not installable Depends: python:any (< 2.8) but it is not installable Depends: python:any (>= 2.7.5-5~) but it is not installable Depends: python-gst-1.0 but it is not installable Depends: gstreamer1.0-plugins-base but it is not installable Recommends: linuxcnc-doc-en but it is not going to be installed or linuxcnc-doc Recommends: linux-image-rt-686-pae but it is not going to be installed E: Unable to correct problems, you have held broken packages.
So...thoughts?
6 years 9 months ago - 6 years 9 months ago #155380 by tommylight
dzawacki wrote: So...thoughts?
Yes, plenty.....
First, wrong kernel, and from that i assume you are running the Wheezy version.
You need the Stretch Preempt-rt version from the download page.
www.linuxcnc.org/testing-stretch-rtpreem...-uspace-i386-r13.iso
Then upgrade Linuxcnc to 2.8 or master (2.9) as Andy and others have mentioned above.
Last edit: 6 years 9 months ago by tommylight. Reason: Link
6 years 9 months ago #155381 by phillc54
That is a RTAI kernel, not PREEMPT RT. That is no good for ethernet Mesa cards.
I think you would be best served with a new clean install from a stretch ISO from here
6 years 9 months ago #155383 by dzawacki
This is what happens when I'm left to my own devices...
I could have sworn I had the right one, but I'll download fresh, flash it, and install and report back.
Thanks everyone for chiming in so far!
6 years 9 months ago #155385 by dzawacki
HEYO! Used the correct iso (which I had downloaded previously but must have mixed it up with another iso) in addition to following phillc54's instructions. I'm able to confirm I'm running 2.8!
Thanks for your help!
Now on to configuring the Mesa 7196.
Time to create page: 0.072 seconds
