First Time Builder - Stuck
- dzawacki
- Thank you received: 6
21 Jan 2020 20:59 #155360
by dzawacki
First Time Builder - Stuck was created by dzawacki
Hello,
I'm relatively new to the CNC world. I've dabbled a bit with a MaslowCNC but other than that I have no experience with them. However, I have a decent background in computers, some of which is with Linux systems.
I came across an old Dahlgren engraver at a price too good to pass on. The plan is to control the existing motors with DM542 drivers, a Mesa 7i96, and LinuxCNC.
All that being said, I'm absolutely baffled as to what I'm supposed to be doing to get this thing up and running. I'm now aware that the 7i96 complicates the issue, but I didn't do enough research before I bought the thing.
So far, I've installed a handful of different flavors of Linux and each of which has their own problems. Ultimately, I'd like to stick with a build of LinuxCNC, upgrade it to 2.8 (as I understand the 7i96 doesn't work on 2.7). Through reading many different posts on somewhat related situations, I've deduced the following:
When I follow the instructions on the buildbot page for upgrading to 2.8, I get to the final stepand I'm told I already have the latest version.
Additionally, throughout my testing, I've tried skipping the upgrade to 2.8 and just installing the 7i96 Configuration Tool on a fresh install of 2.7 using these instructions: jethornton.github.io/7i96/install.html, but running the first command in the console, I get a "python3-pyqt5 not found" error and am unable to proceed.
I've been futzing with this on and off for a few weeks and I'm at the point where I know something is wrong, I just do not know what and where to find the solution. So if any of you wonderful people are able to point me in the right direction, it is much appreciated.
- Install LinuxCNC Uspace 2.7.0 Debian 9 Stretch
- Upgrade 2.7 to 2.8 using the instructions here: buildbot.linuxcnc.org/
- Install the 7i96 Configuration Tool discussed at length in this thread: forum.linuxcnc.org/27-driver-boards/3504...6-configuration-tool
- Configure and play!
sudo apt-get install linuxcncAdditionally, throughout my testing, I've tried skipping the upgrade to 2.8 and just installing the 7i96 Configuration Tool on a fresh install of 2.7 using these instructions: jethornton.github.io/7i96/install.html, but running the first command in the console, I get a "python3-pyqt5 not found" error and am unable to proceed.
- Thank you received: 2181
21 Jan 2020 22:02 #155363
There are buldbot testing debs to install 2.8 so I bet it would work - what did you do to get linuxcnc to download?
using the line:
deb buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
should actually work...
If you get linuxcnc 2.8 you can use pncconf to build a 7i96 config (then you don't need to debug the 7i96 config tool missing libraries).
Chris
Replied by cmorley on topic First Time Builder - Stuck
No where can I see 2.8 mentioned on that page, 2.8 is not officially been released though it's very usable.Upgrade 2.7 to 2.8 using the instructions here: buildbot.linuxcnc.org/
using the line:
Chris
- dzawacki
21 Jan 2020 22:14 #155364
by dzawacki
Replied by dzawacki on topic First Time Builder - Stuck
Yeah, I was wondering if what I was doing was correct because I was expecting to see something indicate 2.8.
A little more background on where I gathered my info from:
To confirm, this command should be run in the terminal:If so, I'll give that a go this evening.
- This post is where I got the indication that I should be using the Debian 9 version: forum.linuxcnc.org/27-driver-boards/3504...rror?start=90#145050
Which is why I downloaded the "linuxcnc-stretch-uspace-i386-r13.iso" from here: www.linuxcnc.org/testing-stretch-rtpreempt/ - This post in no uncertain terms suggested I needed 2.8: forum.linuxcnc.org/27-driver-boards/3504...rror?start=50#136192
deb buildbot.linuxcnc.org/ stretch 2.8-rtpreemptPlease Log in or Create an account to join the conversation.
- Thank you received: 7490
21 Jan 2020 22:18 #155365
Replied by tommylight on topic First Time Builder - Stuck
7i96 should work with 2.7, although i never tested it.
To upgrade you need to add the entries in the menu>system>software sources as per:
then
sudo update
then install linuxcnc
then
sudo update
- dzawacki
21 Jan 2020 22:27 #155366
by dzawacki
Tommy, those instructions are what I was following originally and getting the message that I was already running the most recent version, even though I was working with a fresh install of 2.7
21 Jan 2020 22:32 #155367
did you change the source line to from '....2.7-rtpreempt to '....2.8-rtpreempt' ?
Chris
Chris
- Clive S
- Thank you received: 486
21 Jan 2020 22:36 #155368
by Clive S
Replied by Clive S on topic First Time Builder - Stuck
I have used a 7i92 with 2.7.14 and pretty sure I have also used a 7i96 as well
- AgentWD40
- Thank you received: 96
21 Jan 2020 22:51 #155370
by AgentWD40
Hang in there!! 7i96 just means you need to upgrade your software which in of itself can't be such a bad thing. I've been happy with my decision to get one, and I'll probably be getting another soon for upgrading an old build.
For the record I set mine up with the pncconf wizard which is installed with linuxcnc by default. I think 2.8 is when pncconf started supporting the 7i96. But if I remember correctly using linux 2.7 you could set a config as a 7i76 (or 7i92 or whatever) using pncconf and then just go into the hal/ini files and ctrl-f and replace any references to the 7i76 with the appropriate reference to the 7i96... But that's kind of a hack, I only went to that trouble because I had problems with the 7i96 tool at that time. I'm sure you'll get linuxcnc2.8 sorted out soon enough.
Replied by AgentWD40 on topic First Time Builder - Stuck
Hello,
I'm relatively new to the CNC world. ...
- dzawacki
21 Jan 2020 22:53 #155371
by dzawacki
No, I used the master branch, which might have been my issue. I'll give that a go this evening.
Thanks!
Chris
Thanks!
- dzawacki
21 Jan 2020 22:55 #155372
by dzawacki
I'll keep this in mind if I continue having trouble upgrading to 2.8. Thanks!
