7i96 Configuration Tool
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
13 Sep 2019 06:31 #145050 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
I just discovered that Debian 10 which uses pip3 v18 changes the install so it no longer works. Debian 9 which uses pip3 v9 works fine. It might take me a while to figure this out.
JT
19 Oct 2019 10:11 - 19 Oct 2019 10:19 #148334 by jools
Replied by jools on topic 7i96 Configuration Tool
Hi.
This tool looks great!
I'm trying to install it but have a question about the .xsessionrc bit
I've rebooted but just want to know what should be included in the file I have just created and in what format. Should I create a text document with this in it and call that .xsessionrc?
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
cheers
Jools
No need I uninstalled and reinstalled and it seems to work fine.
Thanks for the software!
Last edit: 19 Oct 2019 10:19 by jools.
08 Nov 2019 21:53 #149960 by Leon82
Replied by Leon82 on topic 7i96 Configuration Tool
I bough a 7i96 card and downloaded the config tool. I haven't gotten the card yet but I played around with the tool a little...
I have 2 para port configs, the one I use and a "test" one to play with and transfer settings to the one I use.
It reads the test one, but gives an error for the one I actually use. Saying some thing about "help". Ill try to screen shot it tomorrow. I'm using stretch and 2.8
12 Nov 2019 13:39 #150242 by Saily2
Replied by Saily2 on topic 7i96 Configuration Tool
Which combo with a thc10... 7i96 or 7i76e ? I'm running 320 gecko servo drives.
14 Nov 2019 17:23 #150394 by Leon82
In my ini file I have ignore limits =yes
I get an error saying yes is undefined.
Should I change yes to a 1?
14 Nov 2019 17:35 #150395 by andypugh
Replied by andypugh on topic 7i96 Configuration Tool
Try YES and also maybe adding a space after the = ?
The following user(s) said Thank You: Leon82
14 Nov 2019 17:47 #150396 by Leon82
I typed it on my phone, but there is a space and yes is all capital
  • Moderator
  • Moderator
14 Nov 2019 17:48 #150397 by tommylight
Replied by tommylight on topic 7i96 Configuration Tool
1
14 Nov 2019 17:54 #150398 by Leon82
1
That worked.
I restarted my machine just to double check they gave me an error that the joint was on the limit switch but it seemed to home fine. Worst case I can change it to yes after after I switch everything over
14 Nov 2019 18:07 #150399 by andypugh
Moderators: PCW, jmelson
Time to create page: 0.150 seconds
