7i96 Configuration Tool
- BigJohnT
- Thank you received: 994
24 Jan 2020 15:17 - 24 Jan 2020 15:18 #155690
by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool error
I just pushed a fix for a Debian 10 Python naming issue where it would not work anymore with an import that started with library name that starts with a number. Not sure if that is related to your issue or not. What OS are you running it on?
What does the following report back when ran in a terminal?
JT
uname -aJT
Last edit: 24 Jan 2020 15:18 by BigJohnT.
- COFHAL
- Thank you received: 62
24 Jan 2020 15:19 #155692
by COFHAL
Replied by COFHAL on topic 7i96 Configuration Tool error
Linux CNC 4.9.0-11-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
DEBIAN 9.9
DEBIAN 9.9
- BigJohnT
24 Jan 2020 16:20 #155696
by BigJohnT
I just tested the install on that same OS with no errors.
What does this return?
JT
$PATHJT
- COFHAL
25 Jan 2020 08:19 #155722
by COFHAL
cnc@CNC:~$ $PATH
bash: /home/cnc/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games: The file or directory does not exist.
cnc@CNC:~$ $PAT
cnc@CNC:~$ $PAT
- BigJohnT
25 Jan 2020 17:14 #155766
by BigJohnT
That looks correct, what happens when you do this in a terminal
I compiled two versions of mesaflash one 32bit and one 64 bit.
If that works and you can't flash the 7i96 then check your address jumper and try an different Ethernet cable. Sometimes on new cards I have to plug/unplug a couple of times before read works. I always make sure read works before flashing.
JT
mesaflash64 --helpI compiled two versions of mesaflash one 32bit and one 64 bit.
JT
- COFHAL
27 Jan 2020 10:59 #155932
by COFHAL
cnc@CNC:~$ mesaflash64 --help
bash: mesaflash64: order not found
cnc@CNC:~$
cnc@CNC:~$
- BigJohnT
27 Jan 2020 17:52 #155967
by BigJohnT
For some reason your install failed, uninstall then carefully following the
instructions
install it again.
JT
JT
- COFHAL
29 Jan 2020 12:58 #156104
by COFHAL
Replied by COFHAL on topic 7i96 Configuration Tool error, Resolved
Now solve the problem, just update the application.
- COFHAL
30 Jan 2020 12:34 #156194
by COFHAL
Replied by COFHAL on topic Configuration GPIO expansion port P1
Why not include being able to program the GPIOs of the expansion port P1?
- Project_Hopeless
- Thank you received: 10
28 Feb 2020 21:19 - 29 Feb 2020 08:35 #158794
by Project_Hopeless
Replied by Project_Hopeless on topic 7i96 Configuration Tool
BJT,
Linux newbie here. About a year ago I load the 7i96 tool on Stretch, no problem. Since then I've changed machines and loaded Mint. Now when I try to load 7i96 Tool I get the following errors.
I have python 2.7 and 3.6, does the version matter? What am i missing?
Can I just download from GitHub and compile the package local?
Update: OK upon further research, Is the tool needed with v2.8? Does the PncConf tool officially work with the 7i96? I really liked the 7i96 tool.
ant@LinuxPC:~$ sudo apt install python3-pip python3-pyqt5 libpci-dev git
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3-pyqt5 is already the newest version (5.10.1+dfsg-1ubuntu2).
git is already the newest version (1:2.17.1-1ubuntu0.5).
libpci-dev is already the newest version (1:3.5.2-1ubuntu1.1).
python3-pip is already the newest version (9.0.1-2.3~ubuntu1.18.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
ant@LinuxPC:~$ pip3 install git+https://github.com/jethornton/7i96.git
Collecting git+https://github.com/jethornton/7i96.git
Cloning https://github.com/jethornton/7i96.git to /tmp/pip-ngv9nkst-build
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-ngv9nkst-build/I have python 2.7 and 3.6, does the version matter? What am i missing?
Last edit: 29 Feb 2020 08:35 by Project_Hopeless.
Time to create page: 0.535 seconds
