7i96 Configuration Tool
26 Mar 2020 04:27 #161538 by rodw
Replied by rodw on topic 7i96 Configuration Tool
I'm using a brand new Mean Well RD-65B dual voltage power supply: 5V @4.0A, 24V @2A. Obviously only running the Mesa card off 5V
This could be an issue. I had one of these and could not it to go for what I bought it for. The company that sold it to me said that the 12 volt rail would not run unless there was sufficient current draw on the 5 volt side. I whacked a big ceramic resistor on 5 volts and I did get 12 volts out of it. I had hoped I could use it for my 7i76e but it did not draw current enough to enable the 12 volt rail.
I wonder if the 5 volt rail is a bit flaky at low current draw too? Much better to use discrete power supplies for each voltage.
The following user(s) said Thank You: gusty42
26 Mar 2020 04:45 #161540 by tommylight
Replied by tommylight on topic 7i96 Configuration Tool
That is very true, same is valid for all PC power supplies till several years back.
The 5V rail is regulated, the 12V is not, so the 5V needs to have some load for the regulation to kick in.
That was due to 5V rail tolerance being +-5%, or 4.75V to 5.25V, and the 12V having a tolerance of +-10% or in some cases even +-15%.
A good phone charger will do just fine for providing 5V, especially original Samsung or any other big company. Steer clear of cheap Chinese knock off's.
The following user(s) said Thank You: rodw, gusty42
26 Mar 2020 12:13 #161559 by gusty42
Replied by gusty42 on topic 7i96 Configuration Tool
Thanks guys for the input on the ps... I did read up about others having issues with their supplies, but thought this would work. I'll try my phone charger next.
@PCW I think some of the hardware info is in the bottom of the debug file I posted, but my initial concern would be the hard drive I'm using. It's a super old 12GB drive and is really loud. Was hoping it would be fine?? Had it laying around... Otherwise, my mb is an Asus A8V Deluxe and I'm using the on-board gigabit ethernet port. 1.5gb of ram I believe.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:11:2f:62:ba:3f brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.9/24 brd 10.10.10.255 scope global eth0
    inet6 fe80::5b6:2fd6:209b:d1ea/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:0c:41:6c:0e:50 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.186/24 brd 192.168.1.255 scope global dynamic wlan0
       valid_lft 5751sec preferred_lft 5751sec
    inet6 fe80::4a84:f54d:f669:8c3e/64 scope link
26 Mar 2020 14:27 #161570 by PCW
Replied by PCW on topic 7i96 Configuration Tool
A failing hard drive can cause large latency spikes but you should be able to check this
by looking at the kernel log (via dmesg)
Another concern is the rather uncommon Marvell Ethernet chip, It might be an issue
( I know BroadCom chips are problematic with real time but these are also rare on current motherboards )
I would try a different power supply and if that does not help the ping times, a different motherboard
28 Mar 2020 22:47 #161851 by gusty42
Check your testcnc.hal if there is a PWM loaded at this line
loadrt hm2_eth ................num_encoder..........num_stepgens ..............num PWM
Not sure how that is all there, just from memory, i think you should have a PWM loaded there.
The error says
./testcnc.hal:99: parameter or pin 'hm2_7i96.0.pwmgen.00.output-type' not found
Or it might not been added to the servo thread.
So, per everyone's recommendations, I've now built up a completely different PC that gives me very consistent pings and pin reads! I'm also using my phone charger for 5V as well, but it's been acting like the PC was the biggest factor here as the original ps gives the same results. The results being what's found in my error report:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-5581-gad29499e8
Machine configuration directory is '/home/cnc/linuxcnc/configs/testcnc'
Machine configuration file is 'testcnc.ini'
INIFILE=/home/cnc/linuxcnc/configs/testcnc/testcnc.ini
VERSION=1.1
PARAMETER_FILE=testcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XY
KINEMATICS=trivkins coordinates=XY
Starting LinuxCNC...
Found file(REL): ./testcnc.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:01:0c
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0:     IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0:     IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0:     IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0:     IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0:     IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0:     IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0:     IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0:     IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0:     IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0:     IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0:     IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0:     IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0:     IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0:     IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0:     IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0:     IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0:     IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0:     IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 025 (TB2-01/TB2-03): IOPort
hm2/hm2_7i96.0:     IO Pin 026 (TB2-04/TB2-05): IOPort
hm2/hm2_7i96.0:     IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0:     IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0:     IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0:     IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0:     IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0:     IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0:     IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0:     IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96.0:     IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96.0:     IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96.0:     IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96.0:     IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96.0:     IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96.0:     IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96.0:     IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96.0:     IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96.0:     IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96.0:     IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96.0:     IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96.0:     IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96.0:     IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96.0:     IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96.0:     IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96.0:     IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
14273
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Sat Mar 28 17:09:56 CDT 2020
            UTC Date: Sat Mar 28 22:09:56 UTC 2020
        this program: /usr/bin/linuxcnc_info
              uptime: 17:09:56 up 1:24, 1 user, load average: 0.38, 0.23, 0.19
     lsb_release -sa: Debian Debian GNU/Linux 9.5 (stretch) 9.5 stretch
      which linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/cnc/linuxcnc/configs/testcnc
                USER: cnc
             LOGNAME: cnc
                HOME: /home/cnc
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: dumb
           COLORTERM:
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size: 1920x1080 pixels (508x285 millimeters)
                PATH: /usr/bin:/home/cnc/linuxcnc/configs/testcnc/bin:/usr/bin:/home/cnc/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: cnc
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=/dev/sda1 ro quiet
          model name: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
               cores: 2
             cpu MHz: 2000.000
             parport:
              serial:
Versions:
                 gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
              python: Python 2.7.13
                 git: git version 2.11.0
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
          glade-gtk2: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.8.0-pre1-5581-gad29499e8
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /etc/init.d/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version                      Architecture Description
un  linuxcnc            <none>                       <none>       (no description available)
un  linuxcnc-dev        <none>                       <none>       (no description available)
un  linuxcnc-doc        <none>                       <none>       (no description available)
ii  linuxcnc-doc-en     1:2.7.14                     all          motion controller for CNC machines and robots (English documentation)
un  linuxcnc-sim        <none>                       <none>       (no description available)
un  linuxcnc-sim-dev    <none>                       <none>       (no description available)
ii  linuxcnc-uspace     1:2.8.0~pre1.5581.gad29499e8 amd64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 1:2.8.0~pre1.5581.gad29499e8 amd64        PC based motion controller for real-time Linux
tommylight: what did you mean by your above statement? I'm using the exact same hal and ini as before but now I've added some spindle info using the configuration tool with hopes this would add what you were saying I might need? Also, after reading the pins with the config tool, my board reports pins 2 and 3 as PWM+/- on TB2, so that seems like my firmware is 4 StepGens and PWM like you're expecting. Any thoughts?
Thanks again in advance!
Matt
28 Mar 2020 22:52 #161854 by PCW
I would verify that the actual loaded firmware has a PWM gen:
mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
28 Mar 2020 23:09 - 28 Mar 2020 23:13 #161857 by gusty42
Correct me if I'm wrong, but I'm not seeing much that looks like PWM... Recommend flashing it as a 4 and 1?
edit: not trying to get off topic, but what if I wanted to run as a 5 axis down the road? Would I just have to define all 5 axis with current firmware to avoid the PWM error and have a "5" in my Board Setup on the first tab of the config tool?
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: Transformer
  There are 1 of Transformer in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
14      1   IOPort       None
 2      2   IOPort       None
15      3   IOPort       None
 3      4   IOPort       None
16      5   IOPort       None
 4      6   IOPort       None
17      7   IOPort       None
 5      8   IOPort       None
 6      9   IOPort       None
 7     10   IOPort       None
 8     11   IOPort       Transformer      0        Drive           (Out)
 9     12   IOPort       Transformer      0        Ref             (Out)
10     13   IOPort       Transformer      0        Null3           (Out)
11     14   IOPort       Transformer      0        Null4           (Out)
12     15   IOPort       Transformer      0        Null5           (Out)
13     16   IOPort       Transformer      0        Null6           (Out)
IO Connections for TB1
 1     17   IOPort       StepGen          0        Step/Table1     (Out)
14     18   IOPort       StepGen          0        Dir/Table2      (Out)
 2     19   IOPort       StepGen          1        Step/Table1     (Out)
15     20   IOPort       StepGen          1        Dir/Table2      (Out)
 3     21   IOPort       StepGen          2        Step/Table1     (Out)
16     22   IOPort       StepGen          2        Dir/Table2      (Out)
 4     23   IOPort       StepGen          3        Step/Table1     (Out)
17     24   IOPort       StepGen          3        Dir/Table2      (Out)
 5     25   IOPort       StepGen          4        Step/Table1     (Out)
 6     26   IOPort       StepGen          4        Dir/Table2      (Out)
 7     27   IOPort       QCount           0        Quad-A          (In)
 8     28   IOPort       QCount           0        Quad-B          (In)
 9     29   IOPort       QCount           0        Quad-IDX        (In)
10     30   IOPort       SSerial          0        RXData1         (In)
11     31   IOPort       SSerial          0        TXData1         (Out)
12     32   IOPort       SSerial          0        TXEn1           (Out)
Segmentation fault
Last edit: 28 Mar 2020 23:13 by gusty42.
28 Mar 2020 23:17 - 29 Mar 2020 01:00 #161861 by PCW
I guess the first question should be:
Do you need PWM?
(and yes that's the standard 5 axis configuration without PWM)
Edit: I think there is a bug in the configurator program that causes it to generate
hal statement referencing PWMgen pins when not required. You may need to simply
delete these statements in the hal file
Last edit: 29 Mar 2020 01:00 by PCW.
28 Mar 2020 23:32 #161866 by tommylight
Again,
Check what PCW said, and if there is a PWM check the line where the card is loaded...............
or just upload your hal and ini files.
28 Mar 2020 23:33 #161867 by tommylight
Sorry, to late.
Moderators: PCW, jmelson
Time to create page: 0.945 seconds
