7i96 Configuration Tool
- BigJohnT
- Thank you received: 994
01 Mar 2020 05:22 #158884
by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
What does uname -a report back?
It's just a python program so no compiling is needed, you can just download it and make sure it's executable and run it.
JT
JT
- Project_Hopeless
- Thank you received: 10
01 Mar 2020 09:30 #158894
by Project_Hopeless
Replied by Project_Hopeless on topic 7i96 Configuration Tool
John I get...
ant@LinuxPC:~$ uname -a
Linux LinuxPC 4.16.12-rt5-kona-rt #1 SMP PREEMPT RT Fri Jun 8 10:39:47 JST 2018 x86_64 x86_64 x86_64 GNU/LinuxPlease Log in or Create an account to join the conversation.
- Project_Hopeless
01 Mar 2020 09:52 #158896
by Project_Hopeless
John,
looking at the Stretch install I see the 7i96.Py in my home dir $local.bin. On this Mint install there is no $.bin directory, just a shared.
Since I'm looking in a hidden directory shouldn't the system create the $.bin?
- BigJohnT
02 Mar 2020 18:22 #159052
by BigJohnT
The home/user/.bin in Debian is not in the path by default. Try $PATH and see if local/.bin is there. If not then do step 3 in the install instructions.
JT
JT
- pascals
04 Mar 2020 10:49 #159203
by pascals
Replied by pascals on topic 7i96 Configuration Tool
Thank you for writing the tool. It made it lots easier to get going. I now have a card which actually drives some steppers. Excellent!
I also ran into the problem the tool didn't want to start, I solved it by just starting it directly from the library dir where all its files live.
- Project_Hopeless
04 Mar 2020 18:30 - 04 Mar 2020 18:30 #159232
by Project_Hopeless
That catches me every time. But it still wouldn't work.
How I got it to work was downloading the python "setuptools" then follow the install instructions verbatim. I found online some issues with Mint and pip without having setuptools. I also had to use the sudo -H switch, something about not having permissions to my own home directory. Can't say I understand, but it does work now.
And a year from now I will have completely forgotten all this.
That was part of it. I had to create the file "xsessionrc" not ".xsessionrc"The home/user/.bin in Debian is not in the path by default. Try $PATH and see if local/.bin is there. If not then do step 3 in the install instructions.
JT
Last edit: 04 Mar 2020 18:30 by Project_Hopeless.
- jay1st
- Thank you received: 17
06 Mar 2020 04:39 #159315
by jay1st
Replied by jay1st on topic 7i96 Configuration Tool
BigJohnT, i'm trying to install the config tool but MINT cant download the PKG from the adress you specIfy
I'v checked Python version, it's the 3, but the PIP3 command is unkown to my Mint
I installed this version and it's running ok, the 7i96 works ok moving all steppers accordingly
02 Mar 2020 04:26 Linux Mint 19.2 MATE with RT_PREEMPT
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=110#158899
- Thank you received: 7504
06 Mar 2020 05:47 #159319
Replied by tommylight on topic 7i96 Configuration Tool
Sudo apt install pip
- hickory43
11 Mar 2020 22:47 #159840
by hickory43
Replied by hickory43 on topic 7i96 Configuration Tool
JT just received my 7i96 card and have been attempting to install the Configuration Tool without success. I have been following your Instructions on Git Hub but continue to receive the following message:
"Collecting git+https://github.com/jethornton/7i96.git
Cloning github.com/jethornton/7i96.git to /tmp/pip-c0w096qq-build
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-c0w096qq-build/"
Can you help me?
Can you help me?
- Project_Hopeless
13 Mar 2020 12:07 #160054
by Project_Hopeless
I received very much the same error.
I had to specifically install python "SetupTools" for what ever reason. Then the 7i96 tool would download and install via the GitHub instructions.
