7i96 Configuration Tool
09 Mar 2021 17:52 #201575 by Vladcronos
Replied by Vladcronos on topic 7i96 Configuration Tool
Oh well, I am probably staying with the CL stepper system I bought, and get servos for my next build later this year. Thanks for the input!
12 Mar 2021 08:45 #201939 by Markyd
Replied by Markyd on topic 7i96 Configuration Tool
Just add:
_not
or
-not
at the end of the 7i96_something_input.000 etc.
tommylight - ref your answer above, the issue i have is the ini and hal files that JohnT's tool produces don't appear to follow 'normal' syntax. for example my ini includes this
[INPUTS]
# DO NOT change the input text
INPUT_0 = Min Limit & Home
INPUT_JOINT_0 = 0
INPUT_1 = Max Limit
INPUT_JOINT_1 = 0
INPUT_2 = Min Limit & Home
INPUT_JOINT_2 = 1
INPUT_3 = Max Limit
INPUT_JOINT_3 = 1
INPUT_4 = Min Limit & Home
INPUT_JOINT_4 = 2
INPUT_5 = Max Limit
but none of this seems to be mentioned in the HAL. I've searched for "INPUT_" and for "Limit" and neither appear in the .hal file. The syntax used (above) in does seem to be conducive to the addition of "_not" or "-not", in fact it specifically says "DO NOT change the input text". I'm at a loss as to how I do something that I thought should be relatively simple. I understand that your answer works in ini.hal files produced by pncconf,
  • Moderator
  • Moderator
12 Mar 2021 10:53 #201944 by tommylight
Replied by tommylight on topic 7i96 Configuration Tool
Can they be modified with the tool? Should have "inverted" or "invert" besides every IO pin.
12 Mar 2021 12:00 #201949 by Markyd
No, not in John's tool, unless he's changed it in the last couple of weeks. Hence asking.
  • Moderator
  • Moderator
12 Mar 2021 14:47 #201970 by tommylight
Upload the hal file, please.
12 Mar 2021 17:04 #201993 by Markyd
Here they are
File Name: harrison_7...5_02.hal
File Size:8 KB
File Name: harrison_7...5_02.ini
File Size:4 KB
  • Moderator
  • Moderator
12 Mar 2021 17:27 #201994 by tommylight
There are no inputs or outputs set up in the attached hal file.
12 Mar 2021 17:36 - 12 Mar 2021 17:37 #201996 by Markyd
Thats what I concluded, but that is the hal file that John's tool generated and the switches are definately working, just the inverse of what I want. Could it be more than one hal file is produced and they are in another one?
Did you look in the ini file, inputs and outputs seem to get a mention in there.
Last edit: 12 Mar 2021 17:37 by Markyd.
12 Mar 2021 17:38 #201999 by PCW
Replied by PCW on topic 7i96 Configuration Tool
The I/O is in io.hal
The following user(s) said Thank You: Markyd
12 Mar 2021 18:00 #202004 by Markyd
OK, I'll have to go fetch it from the shed!
Moderators: PCWjmelson
