First Time Builder - Stuck
- Clive S
- Thank you received: 486
21 Jan 2020 23:04 #155373
by Clive S
The 7i96 is a very good board. I now have used several of them. You have to have the correct version of linuxcnc for any of the Ethernet cards.
Replied by Clive S on topic First Time Builder - Stuck
I'm now aware that the 7i96 complicates the issue, but I didn't do enough research before I bought the thing.
- Thank you received: 2181
21 Jan 2020 23:36 #155374
Replied by cmorley on topic First Time Builder - Stuck
master is fine, 2.8 and master is almost the same.
pncconf in master will configure the 7i96
Chris
Chris
- phillc54
- Thank you received: 2100
21 Jan 2020 23:40 #155375
by phillc54
Open Synaptic Package Manager, Search for linuxcnc and remove it if installed.
Go to Settings - Repositories and make sure the only active entries for linuxcnc are:If you made any changes then click Reload to update the package information.
Search for linuxcnc and it should find linuxcnc-uspace, that is the one to install or from terminal you could enter:
It may be wothwhile before you do all this to open a terminal and enter:and make sure there is "PREEMPT RT" somewhere in the reply to confirm you have an appropriate kernel.
Replied by phillc54 on topic First Time Builder - Stuck
That seems to indicate that you don't have the repositories set correctly.When I follow the instructions on the buildbot page for upgrading to 2.8, I get to the final step
and I'm told I already have the latest version.sudo apt-get install linuxcnc
deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
deb-src http://buildbot.linuxcnc.org/ stretch 2.8-rtpreemptSearch for linuxcnc and it should find linuxcnc-uspace, that is the one to install or from terminal you could enter:
sudo apt-get install linuxcnc-uspaceIt may be wothwhile before you do all this to open a terminal and enter:
uname -aPlease Log in or Create an account to join the conversation.
- dzawacki
- Thank you received: 6
22 Jan 2020 00:34 #155379
by dzawacki
Replied by dzawacki on topic First Time Builder - Stuck
I ranand got:
Runningafter updating the sources in the Synaptic Package Manager gives me the following output:
So...thoughts?
uname -aLinux debian 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/LinuxRunning
sudo apt-get install linuxcnc-uspacedanny@debian:~$ sudo apt-get install linuxcnc-uspace
[sudo] password for danny:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-uspace : Depends: libboost-python1.62.0 but it is not installable
Depends: libc6 (>= 2.15) but 2.13-38+deb7u12 is to be installed
Depends: libfontconfig1 (>= 2.11) but 2.9.0-7.1+deb7u1 is to be installed
Depends: libpango-1.0-0 (>= 1.14.0) but it is not installable
Depends: libpangocairo-1.0-0 (>= 1.14.0) but it is not installable
Depends: libpangoft2-1.0-0 (>= 1.14.0) but it is not installable
Depends: libstdc++6 (>= 5.2) but 4.7.2-5 is to be installed
Depends: libtk8.6 (>= 8.6.0) but it is not installable
Depends: libudev1 (>= 183) but it is not installable
Depends: tcl8.6 but it is not installable
Depends: tk8.6 but it is not installable
Depends: python:any (< 2.8) but it is not installable
Depends: python:any (>= 2.7.5-5~) but it is not installable
Depends: python-gst-1.0 but it is not installable
Depends: gstreamer1.0-plugins-base but it is not installable
Recommends: linuxcnc-doc-en but it is not going to be installed or
linuxcnc-doc
Recommends: linux-image-rt-686-pae but it is not going to be installed
E: Unable to correct problems, you have held broken packages.So...thoughts?
- Thank you received: 7490
22 Jan 2020 00:49 - 22 Jan 2020 00:50 #155380
First, wrong kernel, and from that i assume you are running the Wheezy version.
You need the Stretch Preempt-rt version from the download page.
www.linuxcnc.org/testing-stretch-rtpreem...-uspace-i386-r13.iso
Then upgrade Linuxcnc to 2.8 or master (2.9) as Andy and others have mentioned above.
Replied by tommylight on topic First Time Builder - Stuck
Yes, plenty.....So...thoughts?
Last edit: 22 Jan 2020 00:50 by tommylight. Reason: Link
- phillc54
22 Jan 2020 00:50 #155381
by phillc54
That is a RTAI kernel, not PREEMPT RT. That is no good for ethernet Mesa cards.
I think you would be best served with a new clean install from a stretch ISO from here
- dzawacki
22 Jan 2020 01:37 #155383
by dzawacki
This is what happens when I'm left to my own devices...
I could have sworn I had the right one, but I'll download fresh, flash it, and install and report back.
Thanks everyone for chiming in so far!
- dzawacki
22 Jan 2020 02:35 #155385
by dzawacki
HEYO! Used the correct iso (which I had downloaded previously but must have mixed it up with another iso) in addition to following phillc54's instructions. I'm able to confirm I'm running 2.8!
Thanks for your help!
Now on to configuring the Mesa 7196.
- phillc54
22 Jan 2020 02:38 #155386
by phillc54
That is good, you can use Pncconf for a 7i96
- dzawacki
22 Jan 2020 04:44 #155396
by dzawacki
Does anyone know where there is a good tutorial for configuring using Pncconf for a 7i96? I ran through the config process and only set a few of the options and got the following error message:
PNCconf encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version: UNAVAILABLE
File "/usr/lib/python2.7/dist-packages/pncconf/pages.py", line 1145, in on_xaxistune_clicked
def on_xaxistune_clicked(self, *args): self.t.tune_axis('x')
File "/usr/lib/python2.7/dist-packages/pncconf/tests.py", line 679, in tune_axis
halrun.write("setp "+i+".invert_output true\n")
TypeError: cannot concatenate 'str' and 'list' objectsPlease Log in or Create an account to join the conversation.
Time to create page: 0.136 seconds
