First Time Builder - Stuck
6 years 9 months ago #155428 by dzawacki
Replied by dzawacki on topic First Time Builder - Stuck
AgentWD40 wrote:
dzawacki wrote: Does anyone know where there is a good tutorial for configuring using Pncconf for a 7i96? I ran through the config process and only set a few of the options and got the following error message:
A good one? None that I know of. But here's a bare bones walkthrough of setting up a 7i96 tailored to a simple machine. Lots of babbling and grammar issues but maybe it'll be helpful forum.v1engineering.com/t/lowrider2-plas...ild/13939/6?u=kd2018
You're too humble, this is going to help me far more than guessing would have. I'll have this up while I configure later. It will get me close enough to start. Thanks!
6 years 9 months ago #155659 by dzawacki
Just wanted to report that last night I was finally able to get a motor to rotate!
Thanks to everyone for your help on this.
The following user(s) said Thank You: phillc54, AgentWD40
6 years 9 months ago #155795 by bbsr_5a
Replied by bbsr_5a on topic First Time Builder - Stuck
Get some sleep and Overthink things is many times a better idee to save Nerves and Hardware ;-)
6 years 8 months ago #157671 by J Crowder
I am so frustrated. I was using Mint 19.2 and could not load the 7i96 config tool, used pncconf and could get LinuxCNC to open but not allow me to turn a motor. I then scrapped the whole thing and loaded up Debian Stretch with LinuxCNC 2.7. Went through the process to upgrade and I am now running 2.9 and I got the 7i96 tool to work and produce files. I can open LinuxCNC but it will still not allow me to turn a motor. I do not believe that I am making this too complicated, on the contrary I think I am building it very lean just to get the thing to turn a motor.
The users and moderators here are super helpful and I greatly appreciate all of the advice that I have received and read in other posts. Let me lay out what I have and see if I can get this narrowed down.
uname -a gives me this: Linux linuxcnc 4.9.0-12-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.210-1 (2020-01-20) x86_64 GNU/Linux
I am trying to configure a 3 axis, 4 motor (gantry) cnc router. I have lead screws that are 2 turns per inch, I am using DM542T drivers with 8 microsteps, I have the 7i96 controller, ip is 192.168.1.121. I have NEMA 23 motors, 1.8 degree (23HS45-3504S). My computer speed is:
External Clock: 100 MHz
Max Speed: 4000 MHz
Current Speed: 3400 MHz
Speed: 2133 MHz
Configured Clock Speed: 2133 MHz
Speed: 2133 MHz
I read my Tmax and got this:
Parameters:
Owner Type Dir Value Name
23 s32 RW 0 hm2_7i96.0.read-request.tmax
23 s32 RW 2770320 hm2_7i96.0.read.tmax
23 s32 RW 37894 hm2_7i96.0.write.tmax
I have not flashed my card but I could read it.
I am using Axis GUI
Min Limit is 0 (Home) and the Max Limit is 48 since I have a 48 inch by 48 inch table. How do I figure the Max Velocity and Max Acceleration? I would assume it has to do with the specific motors and drivers but I have not found that information yet. Same thing with Home Offset, Search Velocity, Latch and Latch Velocity. I will keep reading but if anyone can throw me a bone I would appreciate it.
I have attached my basic hal and ini files that I created in the 7i96 config tool.
File Name: deblinuxcnc.hal
File Size:6.67 KB
File Name: deblinuxcnc.ini
File Size:3.96 KB
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago #157675 by BeagleBrainz
Replied by BeagleBrainz on topic First Time Builder - Stuck
How have the stepper drivers been wired to the 7i96 and how are the steppers wired to the stepper driver. It is helpful if you can do a "mud map" of how you have actually wired it, rather than just comment "as per instructions". We all make mistakes, that seems the best way I learn.
Have you correctly identified the wires of each stepper motor correctly ?
How have you set the DIP switches on the driver, has the current been set correctly to match the motors ? According to the data sheet for the motor it is a 3.5amp model.
On Page 9 Item 10 of the DM542T what is the status of the LED mentioned ?
6 years 8 months ago #157677 by J Crowder
Here is what I have: (all drivers and motors are wired/ colored the same way. I have them all on TB1 Step 0-3)
Motor Driver
A-(BLK) A-
A+(GRN) A+
B-(RED) B-
B+(BLU) B+
Driver 7i96
PUL+ Step+ (TB1 pin3)
PUL- Step- (TB1 pin2)
DIR+ DIR+ (TB1 pin4)
DIR- DIR- (TB1 pin3)
The Drivers are set to 3.76A peak, 2.69 RMS. Dip switch 1 is down (ON) with 2 and 3 up (OFF). Switches 4, 5 and 6 are up (OFF) with 7 and 8 down (ON) for 8 microsteps.
The LED on the Driver is a solid green. The red LED is not on at all.
I have 2 - 36V power supplies. Each one powers 2 drivers/ motors. I have a separate 5V power supply to power the 7i96.
