Computer and LinuxCNC latency test
- Thank you received: 7504
02 Mar 2020 16:20 #159043
Replied by tommylight on topic Computer and LinuxCNC latency test
That all looks very nice.
And that is the version you need for the 7i96, that is the Preempt-RT or RT kernel you need, in this case it has also Kona in it's name.
The following user(s) said Thank You: jay1st
- jay1st
- Thank you received: 17
02 Mar 2020 17:12 #159045
by jay1st
Replied by jay1st on topic Computer and LinuxCNC latency test
i used the latest one from March 2020
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=110#158899
So if it's all good for the 7i96 it's good for me
BTW the update manager wants to update the KERNEL, should i let it do it ?
02 Mar 2020 17:17 #159046
Much easier to disable update manager and use
sudo apt update
sudo apt dist-upgrade
That will leave the kernel as is and update all other things...or stuff...
Nope. You can, but you will have to press shift+ctrl at every boot to chose the right kernel, or install grub customizer and change the grub entry.i used the latest one from March 2020
sudo apt update
- BeagleBrainz
- Visitor
02 Mar 2020 17:36 #159047
by BeagleBrainz
Replied by BeagleBrainz on topic Computer and LinuxCNC latency test
In the update manager you can right click on the kernel package it wants to install and select ignore all future "updates for this package" you wont be prompted to upgrade any kernels.
- jay1st
03 Mar 2020 01:12 #159065
by jay1st
OK gurus, that's clear at least
Linux is a steep learning curve when you come from the windows world where most of it is transparent to the userr
Now i have to find a suitable computer for my project
- BeagleBrainz
- Visitor
03 Mar 2020 03:52 #159067
by BeagleBrainz
After a few weeks when you use windows you'll get frustrated, especially when some tasks are easier to do and see what's going on (wrong) using the command line in linux.
Oh and the lack of viruses, trojans and software that wants to spy on you.......and updates only really require a reboot when installing a new kernel. And updates don't require 4 or 5 reboots.
And one of the best things, if you do get an issue with Linux you'll get more than "have you installed the latest drivers and updates". And the price is about right as well.
- jay1st
03 Mar 2020 03:56 #159069
by jay1st
I'm fully convinced about Linux, 100% better than Windows
I'm planning to replace windows on my wife's laptop, as i tryied with this usb live and it was a lot faster.
- BeagleBrainz
- Visitor
03 Mar 2020 04:08 #159070
by BeagleBrainz
If you are going that route, a standard Linux Mint install would be the better option for general everyday use.
Welcome to the Darkside, we have freedom & security.
03 Mar 2020 06:32 #159072
Linux is very user friendly, it's just picky about it's friends !
The following user(s) said Thank You: jay1st, BeagleBrainz
- jay1st
03 Mar 2020 15:12 #159110
by jay1st
So i got hold on an old Fujitsu Siemens computer, With a Celeron @2GHz and it was horrible
Only to get the jitter test running it took like 7mn to have it launched then when running all was frozen
it had a 90µs and 1000K jitter..................damn, but nothing else was working
Trying it on my "old" laptop now
Time to create page: 0.097 seconds
