Computer and LinuxCNC latency test
- jay1st
- Thank you received: 17
04 Mar 2020 03:14 #159174
by jay1st
So the default mode will install LCNC on the HDD or go with the live version running from the bootable USB ?
Replied by jay1st on topic Computer and LinuxCNC latency test
DO NOT SELECT OEM INSTALL
ALLOW IT TO BOOT INTO THE DEFAULT CHOICE AS SHOWN IN MY PREVIOUS POST, THE HIGHLIGHTED ONE
The default selection will work.
OEM install is for Manufacturers of systems and not for a "normal user" install.
I wonder in the OEM item should be removed to prevent this from happening.
- BeagleBrainz
- Visitor
04 Mar 2020 03:23 - 04 Mar 2020 03:24 #159176
by BeagleBrainz
Replied by BeagleBrainz on topic Computer and LinuxCNC latency test
The default selection will boot the live desktop and there is an icon on the desktop to install.
You can use the live desktop to test the latency of a pc run a few sims without installing.
Unless you know what you are doing the best option, on a clean HDD, is to let the installer create the partitions.
If you are still unsure about the install process you can use google to look for howtos on installing Linux Mint as the installer is unmodified. Actually apart from the kernel, linuxcnc, the desktop items pointing to the readme, the forums, github and to install the dev packages (only if you want to rebuild linuxcnc) and the addition of gFTP, geany and midnight commander it is a standard Mint 19.2 ISO.
linuxmint-installation-guide.readthedocs.io/en/latest/boot.html
Last edit: 04 Mar 2020 03:24 by BeagleBrainz.
- jay1st
04 Mar 2020 03:43 #159181
by jay1st
That's what i figured out, i lunched the install from the desktop and let all run by default
- jay1st
04 Mar 2020 13:37 #159211
by jay1st
Yay !!
It works, in the bios and NOT in the BOOT menu but in the Password management there is a BOOT SECURITY manager.......Disabled and now it's running,
Posting from linux cnc
Tnx guys for the help !!!
Now i'm going to try to simulate a cnc connected to the Mesa 7i96 board
- Online
- Thank you received: 7504
04 Mar 2020 14:52 #159221
Replied by tommylight on topic Computer and LinuxCNC latency test
Glad you got it working.
The following user(s) said Thank You: jay1st
- jay1st
04 Mar 2020 15:02 #159222
by jay1st
Tnx to all you !
So now i got the 7i96 to reply from the PING off my PC
Trying to run the sim like you did on your video to see hox it reacts, and of course i'm lost
Tnx to all you !
- jay1st
04 Mar 2020 15:16 #159223
by jay1st
Sim running ok
i guess now i need to do the 7i96 configuration, install plasmaC
- jay1st
04 Mar 2020 16:17 - 04 Mar 2020 16:17 #159228
by jay1st
found this video, and for a noob like me it's gold !
Last edit: 04 Mar 2020 16:17 by jay1st.
- jay1st
06 Mar 2020 03:25 #159304
by jay1st
So finally got all of it working
- BeagleBrainz
- Visitor
06 Mar 2020 04:00 #159306
by BeagleBrainz
Sweet
Time to create page: 0.158 seconds
