Computer and LinuxCNC latency test
- Thank you received: 7504
06 Mar 2020 04:10 #159309
Replied by tommylight on topic Computer and LinuxCNC latency test
Nice.
The following user(s) said Thank You: jay1st
- Pauchuk
02 May 2021 11:43 - 02 May 2021 11:43 #207652
by Pauchuk
Replied by Pauchuk on topic Computer and LinuxCNC latency test
Hey, linux noob here! Been experimenting with latency on 2.7 weezy and would like to see if different version gives different results, so- how to run latency test on mint Xfce? I run it from USB.
Last edit: 02 May 2021 11:43 by Pauchuk.
- BeagleBrainz
- Visitor
03 May 2021 00:44 - 03 May 2021 00:45 #207703
by BeagleBrainz
Replied by BeagleBrainz on topic Computer and LinuxCNC latency test
See here for installing Linuxcnc on Linux Mint (which is really the only option now) forum.linuxcnc.org/9-installing-linuxcnc...-installation#137159
Unless you can get a version of Linux Mint with Linuxcnc pre installed with a real time kernel there isn't much chance of testing Linux Mint & Linuxcnc on USB.
Whilst it would be possible to install Mint to a USB drive it's not a simple issue.
BTW Mint 19.3 is the latest release of Mint that doesn't require a lot of jumping through hoops.
RT_PREEMPT will usually give a latency not as good as RTAI.
It really depends on whether you wish to use the Parallel Port or a Mesa solution.
RTAI for Parallel Port
RT_PREEMPT for Mesa
This is just a general idea.
RT_PREEMPT for Mesa
Last edit: 03 May 2021 00:45 by BeagleBrainz.
Time to create page: 0.106 seconds
