LinuxCNC on Debian 10 Buster quick and easy install
  • BeagleBrainz
  • Visitor
  • Visitor
6 years 3 weeks ago - 6 years 3 weeks ago #185518 by BeagleBrainz
Replied by BeagleBrainz on topic LinuxCNC on Debian 10 Buster quick and easy install
Usually it's an good idea to read any README files in the source tree of any code you intend on building. Most of your issues would have been solved much quicker. Just saying.
Just read the docs, the devs spend time creating them, please take the time to read them, it's only polite.
linuxcnc.org/docs/master/html/code/build...cnc.html#Quick-Start
Last edit: 6 years 3 weeks ago by BeagleBrainz.
6 years 3 weeks ago #185523 by Mduran
that guide is to run linuxcnc in place, without having the linuxcnc executable fura.
I did not use an image provided by linuxcnc.org, I am using a clean distribution of debian 10, I installed the preemp -rt kernel to be able to use uspace and followed this tutorial:
forum.linuxcnc.org/27-driver-boards/3559...w-to-install?start=0
but they use a linuxcnc.org distro with the "linuxcnc already included"
so I think what I need is to install:
echo deb linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee -a /etc/apt/sources.list.d/linuxcnc.list
apart from the one that is installed in place with the "RIP" to be able to configure ethercat.
No linuxcnc RIP installation required to configure ethercat?
  • BeagleBrainz
  • Visitor
  • Visitor
6 years 3 weeks ago #185529 by BeagleBrainz
Since you were compiling from source and running make setuid it was right to assume you wanted a run in place installation.
Did you sign a NDA with yourself that prevents you from actually stating what you want to do ?
6 years 3 weeks ago #185530 by phillc54
BeagleBrainz wrote: Since you were compiling from source and running make setuid it was right to assume you wanted a run in place installation.
That is exactly what I assumed as well.
6 years 3 weeks ago #185531 by Mduran
Rather, since I'm new to installing this from LinuxCNC, I don't know how to explain it well.
In summary what I want is to have the LinuxCNC executable not in place to be able to create QTVCP GUIS with qtdesigner and make it work with ethercat
6 years 3 weeks ago #185533 by phillc54
Mike duran wrote: Rather, since I'm new to installing this from LinuxCNC, I don't know how to explain it well.
You can use Designer and create Qtvcp GUI's in both a package install and a run in place install. Ethercat I would assume to be the same, is it not just some addon components.
Time to create page: 0.394 seconds
