LinuxCNC on Debian 10 Buster quick and easy install
6 years 3 weeks ago #185548 by Mduran
With the installation of packages an executable is generated as in the pre-designed packages?
Sorry, I was wrong
6 years 3 weeks ago #185549 by phillc54
Yes
6 years 3 weeks ago #185551 by Mduran
So to generate a linuxcnc package it would be as follows?
$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc
$ cd linuxcnc
$ git checkout 2.8
$ linuxcnc / debian / => ./configure uspace => cd ..
$ linuxcnc / => dpkg-checkbuilddeps => sudo apt-get install ..... until done.
$ cd ..
$ dpkg-buildpackage -b -uc
6 years 3 weeks ago #185552 by phillc54
Yes, it is all in here:
linuxcnc.org/docs/2.8/html/code/building-linuxcnc.html
But why go to all that trouble when there are ready built packages.
6 years 3 weeks ago #185553 by Mduran
And I tried 2 programs to mount iso images and if it mounts well but at the moment of wanting to install it does not recognize the ssd or hdd to install it and I know that it is not my computer because I tried 3 different, I think the images are damaged or Will the programs be used?
What program do you recommend that works?
Or a pre-designed package that you have already used and works that you can share with me.
6 years 3 weeks ago - 6 years 3 weeks ago #185554 by phillc54
These are the packages I have in Synaptic Package Manager I change between them and they all work.
Warning: Spoiler!
Edit: If you use the buildbot then you need to install the archive signing key:
buildbot.linuxcnc.org/
Last edit: 6 years 3 weeks ago by phillc54.
Time to create page: 1.126 seconds
