RPI4 Raspbian 64 bit & LinuxCNC
- jnp1968
07 Sep 2021 04:24 #219812
by jnp1968
Replied by jnp1968 on topic RPI4 Raspbian 64 bit & LinuxCNC
Hi Aaroncnc
Actually that was my bad, didn't look long (or hard) enough for the right info.
I just found this documentation explaining how to do it, and got way better results. Now I'm just worried about the fan not starting, so will set up CPU temperature monitoring and let it run to get a feeling about how it's doing.
Got this case with build in heatsink and fan, just need to be sure that the fan is actually starting up under linuxcnc.
Thanks for your reply
- Thank you received: 4648
07 Sep 2021 12:26 #219846
www.linuxcnc.org/dists/buster/base/binary-armhf/
However LinuxCNC doesn't have any files for arm-64.
If we decide to start offering a 64 bit image then that would need to be added. (not difficult)
Replied by andypugh on topic RPI4 Raspbian 64 bit & LinuxCNC
For armhf it is available from the LinuxCNC repository
This looks to me like the python-gtksourceview2 module is missing.
- BigJohnT
- Thank you received: 994
19 Oct 2021 12:50 #223555
by BigJohnT
Replied by BigJohnT on topic RPI4 Raspbian 64 bit & LinuxCNC
Just trying this on my Rpi4 and the clone line seems to be off
john@raspberrypi:~ $ git clone github.com/LinuxCNC/linuxcnc.git emc
fatal: repository 'github.com/LinuxCNC/linuxcnc.git' does not exist
JT
JT
- BigJohnT
19 Oct 2021 12:51 #223556
by BigJohnT
One more thing
john@raspberrypi:~/emc $ debian/configure uspace
uspace is accepted for compatibility, but ignored
successfully configured for 'uspace-Debian-10'..
JT
JT
- BigJohnT
19 Oct 2021 16:14 #223572
by BigJohnT
- cakeslob
- Thank you received: 280
19 Oct 2021 23:28 - 19 Oct 2021 23:30 #223604
by cakeslob
Replied by cakeslob on topic RPI4 Raspbian 64 bit & LinuxCNC
How is it with isolcpus 1,2,3?
Last edit: 19 Oct 2021 23:30 by cakeslob.
- Thank you received: 7463
20 Oct 2021 00:38 #223608
Replied by tommylight on topic RPI4 Raspbian 64 bit & LinuxCNC
I have seen worse, and worked quite reliably with Mesa 7i92.
Attach a Mesa board to it, leave it on for a day or two and do stuff occasionally see if it drops the link.
- Thank you received: 4138
20 Oct 2021 02:22 #223618
Replied by rodw on topic RPI4 Raspbian 64 bit & LinuxCNC
I also think this is fine for a Mesa card. I don't know if it will work on a PI but isolcpus=1,2,3 idle=poll made a significant difference on my J1900I have seen worse, and worked quite reliably with Mesa 7i92.
- BigJohnT
20 Oct 2021 11:17 #223653
by BigJohnT
I'm going to try with a 32 bit raspi os. This is just for testing my Rpi GPIO tool and figuring out the man page for hal_pi_gpio component.
JT
JT
- elovalvo
- Thank you received: 127
23 Oct 2021 05:42 #223974
by elovalvo
Replied by elovalvo on topic RPI4 Raspbian 64 bit & LinuxCNC
But have you tried this newer version of the 64-bit Raspbian OS with Preempt-RT?
forum.linuxcnc.org/9-installing-linuxcnc...blem?start=90#217552
Time to create page: 0.346 seconds
