Password required to start LinuxCNC from USB stick
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
18 Sep 2020 11:33 #182630 by BeagleBrainz
Replied by BeagleBrainz on topic Password required to start LinuxCNC from USB stick
With Rufus I could install LinuxCNC on the stick and my old computer boots successfully from it, whereas my newer one is still asking for a password.
Well you have already established that the issue with the newer machine is you don’t know the BIOS password. This isn’t an issue with Linuxcnc.
The only option maybe to contact the seller or the manufacturer of the machine and try and resolve the issue that way.
  • Moderator
  • Moderator
18 Sep 2020 11:35 #182631 by tommylight
Is the one that asks for password a desktop or a laptop ?
18 Sep 2020 12:00 - 18 Sep 2020 12:04 #182635 by Aloha
a desktop
Finally that will not be my greatest problem: my real problem will be to be able to use the not so easy program!
Does LinuxCNC turn on a Raspberry Pi?
Last edit: 18 Sep 2020 12:04 by Aloha.
  • Moderator
  • Moderator
18 Sep 2020 12:35 #182641 by tommylight
All desktop PC's have a "clear CMOS" jumper on the mainboard, the new ones have a small button for that, just be sure the PC is unplugged before you do so. That will clear all passwords and set the BIOS to factory defaults. Also beware that if you have any type of RAID setup, that will most probably make them non usable. This is only if the PC came with two or more of the SAME drives from factory, so chances are very low.
Machinekit ( a fork of LinuxCNC ) runs on RPI3 while the normal LinuxCNC runs on RPI4 and the ready made image can be downloaded here:
linuxcnc.org/downloads/
18 Sep 2020 14:19 #182652 by Aloha
Thank you very much for that interesting information!
I have found some tutorial videos on Youtube to learn how to use LinuxCNC.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
18 Sep 2020 20:44 #182680 by Todd Zuercher
Replied by Todd Zuercher on topic Password required to start LinuxCNC from USB stick
Most do, but not all. I bricked an old Dell once, trying to update the BIOS, that didn't have any fail safe reset.
24 Sep 2020 13:40 #183588 by Aloha
Finally, there is only one video that is interesting, but it isn't really a tutorial to get started with LinuxCNC.
Therefore my question: does someone know how to find tutorials?
  • BeagleBrainz
  • Visitor
  • Visitor
24 Sep 2020 14:04 - 24 Sep 2020 14:10 #183591 by BeagleBrainz
Apparently search engines are quite popular with the younger crowd.
Reading the docs is a good start.
linuxcnc.org/docs/2.8/html/
Browsing the forum will help.
Running one of the many sims will give you a feel for the UI.
Draw some simple shapes in CAD create gcode via your favourite CAM program and run that.
There is also gcode examples supplied with Linuxcnc.
Running thru Stepconf or Pncconf is not much harder than it is with Mach. Don't forget the docs are included with Linuxcnc.
2 seconds of searching Youtube
www.youtube.com/playlist?list=PLa_L8q5ve...zP_yOKBXPB8zKn-iWCsX
Last edit: 24 Sep 2020 14:10 by BeagleBrainz.
  • Moderator
  • Moderator
24 Sep 2020 14:06 #183592 by tommylight
24 Sep 2020 14:15 - 24 Sep 2020 14:34 #183595 by Aloha
Thank you very much!
I had forgotten to mention, that I have searched for tutorial videos in German or French, because I have often difficulties understanding acoustically the comment in many American videos if the author doesn't take care of his pronounciation, as f.i. in the 3rd linked video.
Last edit: 24 Sep 2020 14:34 by Aloha.
Time to create page: 0.124 seconds
