Password required to start LinuxCNC from USB stick
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
24 Sep 2020 14:38 - 24 Sep 2020 14:43 #183600 by BeagleBrainz
Replied by BeagleBrainz on topic Password required to start LinuxCNC from USB stick
I see the problem, well no worries.
Well you are in luck Talla83 has some great stuff. I really wish I understood German.
www.youtube.com/channel/UCHDMxw4Oum-wKm5UpMt2lzA
Unfortunately I'm a Luddite and speak a broken version of English eg: Australian and forget that there are other smarter people who are multi lingual.
Last edit: 24 Sep 2020 14:43 by BeagleBrainz.
05 Oct 2020 15:24 - 05 Oct 2020 15:24 #184975 by seuchato
In noticed this when testing - but forgot to mention.
While runing live, if you wait too long doing nothing, a password is required to regain the desktop again.
I never did find out what the password was.
Got this very problem solved like this, when the live stick fell into screen saver. Thereafter, the login screen appears and the above described problem raises:
  1. press Ctrl-Alt-F1 to get to a textconsole
  2. (on the live stick) you will see a prompt like "user:>"
  3. enter sudo su
  4. check with "whoami" that you are "root" now
  5. enter "passwd user"
  6. enter the same "password" (does not have to be fancy, as the live stick is not {yet?} persistent) twice
  7. with Ctrl-Alt-F7 you will get back to the graphical login screen
  8. Enter user "user" and Password "password"
  9. you should be back inyour live stick desktop
hth
chris
Last edit: 05 Oct 2020 15:24 by seuchato.
06 Oct 2020 13:30 #185068 by andypugh
The default user/password on the debian LiveCD is
username - user
password - live
In the case of the LinuxCNC Raspberry Pi image it is
username - pi
password - raspberry
The following user(s) said Thank You: seuchato, jay.perez1
  • Moderator
  • Moderator
06 Oct 2020 14:37 #185077 by tommylight
The OP had issues with BIOS password so could not choose the boot device.
08 Oct 2020 08:14 #185338 by Aloha
Thank you very much for the information.
Since my last post I didn't do anything about LinuxCNC, the reason why I answer only now.
07 Mar 2021 17:02 #201315 by Aloha
As I have meanwhile bought a mill -but I still have to assemble it- I tried to start LinuxCNC and it asks at once for the password. I had totally forgotten that.
07 Mar 2021 19:26 #201337 by andypugh
Would much be lost if you did a clean install and remembered a new password?
07 Mar 2021 19:40 #201341 by Aloha
Yes, I'll do that, but I didn't choose a pwd!
  • Moderator
  • Moderator
07 Mar 2021 21:22 #201362 by tommylight
Are we talking about a BIOS password, a HDD password (again in BIOS) or a Linux Desktop password ?
07 Mar 2021 21:40 #201367 by Aloha
After the discussion here over 4 pages it seems to be a BIOS pwd.
Time to create page: 0.254 seconds
