ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
  • twoflowers
  • twoflowers's Avatar Topic Author
  • Visitor
  • Visitor
09 Oct 2020 01:32 - 12 Jul 2021 05:07 #185431 by twoflowers
Images gone - say thanks to CoC policemen. [b]Don't forget: OBEY![/b]
Last edit: 12 Jul 2021 05:07 by twoflowers.
09 Oct 2020 01:44 #185432 by Aciera
Please excuse my ignorance, but what architecture is this for?
  • twoflowers
  • Visitor
  • Visitor
09 Oct 2020 02:00 #185433 by twoflowers
amd64 (thanks, added it in the description)
09 Oct 2020 04:02 #185447 by Aciera
Hm, interesting. Never heard of that distro, thanks.
  • twoflowers
  • Visitor
  • Visitor
02 Nov 2020 13:47 #188145 by twoflowers
As TDE was updated to 14.0.9 I uploaded a new release (link in 1. posting). I also added Arduino IDE :)
  • Moderator
  • Moderator
02 Nov 2020 15:27 #188155 by tommylight
Gave it a quick run, it works and it is snappy ! :)
03 Nov 2020 02:52 #188193 by partec
Danke, interessant und funktioniert, das Desktop Hintergrundbild allein ist einen Blick wert, ich habe auch bei devuan wiki hineingeschaut :)
nebenbei, ich war etwas erstaunt,
Wilkommen
bei der Oberflächenvorbereitung sollte noch deutsch verbessert werden
  • twoflowers
  • Visitor
  • Visitor
03 Nov 2020 12:26 - 03 Nov 2020 12:27 #188247 by twoflowers
Good you like it:)
Das TDE Projekt trinitydesktop.org freut sich über jeden, der an der Verbesserung der Übersetzung mitmacht - Kommunikation über die Mailingliste.
Last edit: 03 Nov 2020 12:27 by twoflowers.
08 Dec 2020 01:24 #191391 by whoppa
Wow this is great. I installed to a partition on my hard drive. As not so great with linux I struggled a bit to work out how to boot it. Then I found that In my existing install sudo update-grub did the trick. I imported my machine config and its running sweet. Thanks
08 Dec 2020 06:52 - 08 Dec 2020 12:40 #191413 by Clive S
(Note: Check GRUB settings)
I have tried this ISO and it seems to be snappy as Tom says.
But I am having trouble to get it to boot from the HD. I can see all the system files on the drive etc.
Can you please help with getting it to boot from the sata drive.
Edit: I copied the ISO to a USB with Win32DiskImager to make it bootable
Edit: If I install mint on another partition on the hard drive and use the boot menu on that I can then pick the appropriate boot to boot the the Exegnulinux system.
But I don't seem to be able to get the grub on its own.. I get the error PXE-E53 No boot file received
Last edit: 08 Dec 2020 12:40 by Clive S.
Time to create page: 0.211 seconds
